Old 08-31-2009, 07:41 PM   #16
~Driver~'s Avatar
Back Pocket Racing
Team Associated SC10 4x4
~Driver~ is offline   Reply With Quote
Old 08-31-2009, 08:49 PM   #17
houston's Avatar
Trader Rating: 91 (100%+)
flywheel ☻ § °
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 09-01-2009, 01:26 PM   #18
david628@ckt.ne's Avatar
Originally Posted by beta bob View Post
Im getting ready to break in a GRP my first .21 and i like this method and found it really helpful but at the end of part 1 he was talking about the temps dropping after a couple of half tanks on the ground and i was wondering do you lean the highspeed or lowspeed to keep the temp up to 210 or do you just let the engine temps go down?
bob, as After Heat cycling, I am running around easy and the engine temp usualy will take a sudden engine temp drop , I will lean the hsn 1/2 hr at a time.I try keeping temp around 210 , also the LSN can and will effect the engine temp, I always run the LSN rich ( engine will load up at 10-15 sec of idle) during breakin. But I do not want the LSN so rich I die easy because its over rich( I always try and keep the engine running to prevent from having to start the engine over again). I will usualy set the LSN correctly after I feel the engine is pretty much loosened up well ( broke in). Also remember when you lean the HSN it will lean the LSN at the sametime to some degree, Hope this helps, Dave
david628@ckt.ne is offline   Reply With Quote
Old 09-01-2009, 02:04 PM   #19
LabRat99's Avatar
The three best ways to stop your engine:
1) Flywheel
2) Flywheel
3) Flywheel
LabRat99 is offline   Reply With Quote
Old 09-01-2009, 03:02 PM   #20
beta bob's Avatar
Trader Rating: 2 (75%+)
Ok thanks i found this video more helpful then the one at the top of the off road forums
Team Terribles---------2009 post of the year
"Cant you read Mopar???He said that he drives a T-max 2.5!!!!"
Spec classes are for communist
beta bob is offline   Reply With Quote
Old 09-02-2009, 03:33 PM   #21
apollo1983's Avatar
Default prime
another question - when pre-heating the block with a heat gun, the pressure seems to push the fuel out of my primed fuel line. When I try to reprime before starting, it doesn't take. It has to cool down to about 140 before the prime will take.
I do have a relatively short fuel line, will try a long one coiled one like in the video, but figured I'd ask anyway.
apollo1983 is offline   Reply With Quote
Old 09-02-2009, 06:30 PM   #22
apollo , if fuel bleads back while preheating, - put the glow igniter on with right hand, put a left hand finger on the pipe outlet and push down with the ingniter so, priming it back up to the carb while turning over the engine at same time , when you see the fuel hit the carb then just release your finger , then if needed you have a hand free to work the remote or the carb slide to get er fired up, Dave
RC FLIGHT brading Manila Racers 23110 12-24-2015 06:23 PM
RDLogics Mongoose KMac Nitro On-Road 2117 03-09-2011 12:57 AM
Wheels Wings N Hobbies Summer Schedule Mike L. Minnesota and North/South Dakota Racing 40 09-22-2008 09:37 PM
2006 Dash for Cash Series @ Dirt Heaven in Green Bay, WI (BIG PAYOUT!!!) Brandon Rohde Wisconsin & Illinois Racing 146 09-18-2006 10:54 AM
Team Magic G4 Family--The Joy of Driving nickko Nitro On-Road 75 12-12-2005 09:45 PM
