8ight 1.0 RTR Chassis mod for starter box???
I have an 8ight 1.0 rtr and an RB wS7... Can I mod the the chassis to accept my starter box, or will a 2.0 rtr chassis work ORRR do I have to buy the 1.0 pro chassis????? PLEASE HELP
Yes the RTR chassis can work but you have to do two things:
1) Buy the Losi pro engine mounts so the engine sits lower on the chassis.
2) Use a file to slightly widen the flywheel hole in the chassis.
I used a RTR chassis on both an OFNA and Losi bump box. No need to file, you just need to change the motor mounts to lower the fly wheel.
I recommend this setup for easy clutch changing
http://www.amainhobbies.com/product_...ght-8ight-T-20
http://www.overdriverc.com/proddetail.php?prod=LOSA9154
RTRs came with a different, cheaper part.
Joe Cool is spot on!!! The quick change engine mounts are the way to go. It makes cleaning quick, clutch maintenance easy, clutch adjustment a breeze, and you can get extra top blocks to mount on different engines. That way several engines can be ready to go at any time. So nice.
I use the king headz extended quick change mount in my truggy and regular king headz quick change mount in the buggy. It makes taking the engine in and out a snap and yes you can have a backup engine ready to go and sway it out in minutes. Best way to go.
King headz quick change engine mount <<click here<<
King headz regular engine mount <<click here<<
They are nice, no question about that:
http://www.overdriverc.com/proddetail.php?prod=LOSA9155
http://www.overdriverc.com/proddetail.php?prod=LOSA9156
