Old 08-18-2009, 09:31 PM   #1
xBRxSAIGON's Avatar
Default 8ight 1.0 RTR Chassis mod for starter box???
I have an 8ight 1.0 rtr and an RB wS7... Can I mod the the chassis to accept my starter box, or will a 2.0 rtr chassis work ORRR do I have to buy the 1.0 pro chassis????? PLEASE HELP
B4 stock ~ SC10 stock ~ CRT X2 ~ RC8B
Trinity ~ Savox ~ JConcepts ~ Proline
SpeeedPasion ~ Novarossi ~ upgrade
xBRxSAIGON is offline   Reply With Quote
Old 08-19-2009, 09:43 AM   #2
Signal151's Avatar
Yes the RTR chassis can work but you have to do two things:
1) Buy the Losi pro engine mounts so the engine sits lower on the chassis.
2) Use a file to slightly widen the flywheel hole in the chassis.
Durango DNX408 - Orion Alpha CRF MTE | Nitrotane | Competition Heat | JR Racing | Savox | AKA Tires | Ascendancy
Losi 8IGHT 2.0 - nVision S21 R | Nitrotane | Competition Heat | JR Racing | AKA Tires | Outerwears | JConcepts | DE Racing
Losi 8IGHT-E - Excelorin Brushless | HITEC | 4s G-Force LiPo | AKA Tires
Signal151 is offline   Reply With Quote
Old 08-19-2009, 12:09 PM   #3
Trader Rating: 33 (100%+)
I used a RTR chassis on both an OFNA and Losi bump box. No need to file, you just need to change the motor mounts to lower the fly wheel.
I recommend this setup for easy clutch changing
http://www.amainhobbies.com/product_...ght-8ight-T-20
Joe..Cool is offline   Reply With Quote
Old 08-19-2009, 12:10 PM   #4
khudzik's Avatar
This should be the mount, it is stock on the Race Roller versions:
http://www.overdriverc.com/proddetail.php?prod=LOSA9154
RTRs came with a different, cheaper part.
khudzik is offline   Reply With Quote
Old 08-19-2009, 02:40 PM   #5
air8's Avatar
Joe Cool is spot on!!! The quick change engine mounts are the way to go. It makes cleaning quick, clutch maintenance easy, clutch adjustment a breeze, and you can get extra top blocks to mount on different engines. That way several engines can be ready to go at any time. So nice.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 08-19-2009, 03:12 PM   #6
Frank L's Avatar
Trader Rating: 148 (100%+)
I use the king headz extended quick change mount in my truggy and regular king headz quick change mount in the buggy. It makes taking the engine in and out a snap and yes you can have a backup engine ready to go and sway it out in minutes. Best way to go.
King headz quick change engine mount <<click here<<
King headz regular engine mount <<click here<<
Old 08-19-2009, 03:30 PM   #7
khudzik's Avatar
They are nice, no question about that:
http://www.overdriverc.com/proddetail.php?prod=LOSA9155
http://www.overdriverc.com/proddetail.php?prod=LOSA9156
