Whats NEXT???
#31
I could see EFI down the road, everyone said it would never be done on dirt bikes, now i think there is only one manufacture (yamaha) that still used a carb in the AMA circut. i could see a usb connection and electrical tuner to the engine. you could only tune the engine once a run but you wouldnt have to have your buggy carring all that hardware
#33
I would actually like to see a set-up that requires no battery for power(or a very small one just incase the engine dies to power the electronics for a minute or so). On small motors they do not have an altornator, they have a different set-up to produce the electricity to power the spark plugs. Why couldn't a set-up be made to adapt over to our engines? We already have the voltage regulators to regulate the power to receivers.
#36
they have EFI in rc airplane engines fyi.
Nitro has to come up with something. Someone whether it be ae, losi, kyosho will come out with a true 1/8 electric and the class will really take off. I don't see nitro coming up with anything unless the scale gets larger. That would allow for the complicated mechanisms you guys are talking about. I mean you can try to make them lighter, or try to squeeze a few more thousand rpms out this little engines. But really i don't see much else. The buggies out now are just awsome.
4 stroke could possibly come. That would be cool. 10 years from now we will be saying "remember how much a pain in the ass it was to tune the carbs"
#37
http://www.youtube.com/watch?v=-uddNtWwguI
Purpose built electrics are coming although I don't think they are going to be much different than the nitros. We might see a belt drive though.
I would love to see more rc on television, but face it. RC isn't really a tv friendly sport. It can get boring from a spectator perspective.
#38
I can see 4-strokes in the future. They can be made to rev alittle higher than the conservative settings in todays airplanes. They can pull a higher gear as well, so I'd think that eventually they'd outclass 2 strokes. Less fuel consumption as well. Not sure we'll like the extra maintenance. Then again its a mute point, these would be no more legal to race than our E buggies/truggies.
How about shocks with independant rebound damping circuits. We dial in our compression damping but our rebound damping ends up way too stiff. There's alot more traction to be had if we'd get some real shocks, not an easy idea, but its doable.
Efi is lame, seen it with the Os airplanes. Do you really want to pay an exra $500 per engine just to avoid turning a little screw a quarter turn before a race. Do not want.
#39
More use of ceramics in engines. I know that there is a new engine with a ceramic piston, but do a piston/sleeve (less expansion difference due to similar materials, thus less taper, thus last longer) and possibly a ceramic block. Toyota/Lexus has already built engines with ceramic blocks that worked well, just not cost effective at this time. It is also more stable when hot, not much expansion/contraction.
Just my 2c.
Just my 2c.
#42
Purpose built 1/8th scale electrics are right around the corner.
Just take a look at the Ve8
#43
I would love for this to happen. It should be possible with the larger shocks on the 1/8 scale stuff now.
#45
