Old 08-17-2009, 04:42 PM   #1
Cory Kerber's Avatar
Default Inconsistent Idle- Bearing Leak?
My Grp tuned started idling inconsistently. Sometimes when i come off the throttle it's at a high idle, sometime a low idle. If i just let it idle it will go from low to high and back again. The only leak i could find is the front bearing. If i open the carb and blow through the fuel intake i can hear some air coming from the front bearing. Is this significant enough to be the reason for my idle problem? I've already went back to factory needle settings and re-tuned to the same result.
I just figured i'd ask before i spent $15 on a new TKO. Thanks
Losi 8ight-Novarossi N21R-Hitec Servos-AKA-M11 Spektrum
*TEAM TERRIBLES*
Cory Kerber is offline   Reply With Quote
Old 08-17-2009, 05:10 PM   #2
I've been there. Change the front bearing.
Team HRC Raceway - http://www.hrcraceway.ca/
Semple is offline   Reply With Quote
Old 08-17-2009, 05:11 PM   #3
markr04's Avatar
I saw a post 2-3 weeks ago that explained how a front bearing can be completely open and have no effect on anything like that... that the shields are just for dirt and not vacuum.
It was in this off-road forum if you wanna search for it.
EDIT: Correction, it said it would have an effect on tune... but people tune to open bearings just as you'd tune to sealed bearings.
Xray 808 2010 Spec - O.S. V-Spec Speed - Airtronics M11-DSSS
Losi 8ight-T 2.0 - RB Killer 9 - Airtronics M11-FHSS-2
Losi XXX-CR - Tekin RS / Novak Ballistic 13.5 - Airtronics M11-FHSS-2
markr04 is offline   Reply With Quote
Old 08-17-2009, 05:21 PM   #4
Trader Rating: 47 (100%+)
A short burst of WD40 will let you know.
With the engine running, aim the straw
of your WD40 at the back of the flywheel
and give it a short burst. If it shuts the engine
off, then you know the bearing is leaking and
the bearing needs to be replaced.
rageworks is offline   Reply With Quote
Old 08-17-2009, 05:22 PM   #5
You had the same idling problem, and the bearing solved it?
I found that post, but now i'm confused on what to do to fix my problem. Looking for more opinions.
That's what i was looking for, i'll try that this evening and let everyone know.
*TEAM TERRIBLES*
Old 08-17-2009, 06:21 PM   #6
Weird, i go out there to check the bearing with WD-40 and the idle is fine. The engine was very rich for some reason. The only thing i can think of was that there was a leak that i fixed yesterday when i checked/resealed. That caused the engine to go back to normal so making it rich. I have to go now, so i'll keep trying later/tomorrow. Thanks Guys.
*TEAM TERRIBLES*
Old 08-18-2009, 07:04 PM   #7
could be losing pressure some where. check pressure on tank, and exhaust seals. Could have a hole in the presure line. Hope this helps.
bigde2001 is offline   Reply With Quote
Old 08-18-2009, 07:54 PM   #8
Might only happen when hot like running race pace for a few min.Alum blocks grow a bit when heat soaked & then the problems show up.Worth a check if the neibors dont get mad.
"TEAM TERRIBLES"
butch man is offline   Reply With Quote
Old 08-18-2009, 10:08 PM   #9
I actually found that my pressure line was melted at one spot. So that may have been the problem. Once i fixed that, the engine richened up. The tanks/seals were good.
I'll get some tanks in tomorrow, so hopefully i can compare to see if it only happens when it gets hot. I live in the country, so i don't have to worry about neighbors. Except for my grandparents who live across the street. It's like "Everybody Loves Raymond"
*TEAM TERRIBLES*
Old 08-18-2009, 10:49 PM   #10
I'm so sorry
"TEAM TERRIBLES"
Old 08-19-2009, 07:21 AM   #11
Yep. My bearing was leaking, to the point of leaking a puddle under the engine mount. My idle was erratic. Wouldn't hold a tune, kept leaning out, etc.
JP engines jasoncsc Onroad Nitro Engine Zone 1160 05-10-2017 07:19 AM
GRP... Engine... Thread... xlgraphicspro Offroad Nitro Engine Forum 2135 09-10-2013 08:46 AM
JL Racing .12 nitrodude Onroad Nitro Engine Zone 2083 05-16-2012 01:21 PM
