Old 08-16-2009, 05:44 PM   #1
Default my v-spec.
I was told that my vspec would only last 3 gallons 5 at the most, because it was my first brand new engine and learning how to tune and all. Not to mention vspec's are not durable and don't last.
well i broke it down and inspected it after 5 gallons and the p/s still have pinch, the piston (well oiled) is 3/16th or 4mm from the top of the sleeve (does this sound good?). the con rod and crank have a very small amount of play. the piston has deposits but i see myself getting another 3 gallons at least. The only thing i don't know how to check is the bearings. They still look and feel like the day i got the engine!!
and considering all the hell i put it through i never though it would last this long. I must have got a good one!
btw, does 3/16 sound good? i cannot pust it past the line without using considerable resistance.
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 08-16-2009, 05:49 PM   #2
Put your head and head button back on with your low plugs, and flywheel. How is the compression when you turn the flywheel? I should have a good amount of resistence. The 3-5 gallon range is when you get the OS Speed/Ninja rod and put TKO ceramic bearings in your v-spec, then it will be better than ever. ANY slop in the rod/crankshaft pin is VERY bad. REPLACE the rod with the OS speed/Ninja rod and that will help out alot.
I dont know about the 4mm thing, but just check your compression!
Losi 8ight 1.5 ~ 8T ~ XXX Buggy ~ Mini-Baja
The o''le saying goes, pay me now, or pay me later, because you gonna pay me. "Pearl_414"
Chris__RC is offline   Reply With Quote
Old 08-16-2009, 05:51 PM   #3
freestylinmotox's Avatar
5 gallons should be the minimum lifetime you get out of your v-spec.
Ive seen v-specs last anywhere from 5 gallons to 20 gallons with just a simple conrod change and or p/s change.
Treat your v-spec well and maintain it and it will last quite a while for you!!
when in doubt, throttle out! braaap!
freestylinmotox is offline   Reply With Quote
Old 08-16-2009, 06:37 PM   #4
well the play is small. and i do not know if it is the rod or crank. Is there a way to tell?
Mugen
Old 08-16-2009, 07:07 PM   #5
If there is ANY, and I mean ANY play, replace the rod with the speed rod.
Old 08-16-2009, 08:46 PM   #6
whats the difference between the 2? just curious, I haven't looked up the specs
akiyama77 is offline   Reply With Quote
Old 08-16-2009, 09:07 PM   #7
What 2 are you talking about?
Old 08-16-2009, 10:33 PM   #8
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
V-specs can get great lifetime if taken care of. Mine is just now starting to show signs of wearing out, and it has 11+ gallons on it so that's reasonable. I would recommend a rod and bearing change. If it's still got good compression a rod and bearing change will extend the lifetime. You can check your crank pin with a good set of digital calipers.
As for the difference between the 2 rods(assuming that is what akiyama77 is talking about), the ninja/speed rod is much better. It is made better, and has an oiling hole in it to provide better lubrication. It is a great upgrade for the standard v-spec, and is only $5-10 more than the standard v-spec rod.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Kyosho V-ONE RRR EVO 2 boy2rc Nitro On-Road 2803 10-04-2014 11:50 AM
Kyosho v-one rrr doki_doki Nitro On-Road 9839 08-07-2014 03:59 PM
Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks. John Stranahan Electric On-Road 2178 12-01-2010 10:26 AM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 07:19 AM
FS mini-t pro Brushless muck R/C Items: For Sale/Trade 7 12-09-2008 04:31 PM
Matched Cell Problems. Mosc_007 Australian Racing 282 01-27-2007 11:34 AM
