Old 08-15-2009, 04:49 PM   #16
Jaz240's Avatar
Trader Rating: 52 (100%+)
Josh your video made me want to go play with my buggy...be right back
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 08-15-2009, 04:50 PM   #17
jhipps835's Avatar
Trader Rating: 13 (88%+)
Ok i will stop blipping the throttle. But i was told to give about 1/4 throttle for first couple of tanks. And if it sounds lean i guess i will have to richen it up.
Losi 8ight 2.0 - O.S V-Spec - Futaba - AKA - M8 - Spektrum - Byrons 20%
jhipps835 is offline   Reply With Quote
Old 08-15-2009, 04:51 PM   #18
jhipps835's Avatar
Haha... Dont leave i need your help!
Old 08-15-2009, 04:53 PM   #19
Jaz240's Avatar
I wish I was talented enough to tell from your video if it was rich or lean, sorry, If JamminKrazy can't help you, nobody can ( at least via web)
Old 08-15-2009, 04:53 PM   #20
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Originally Posted by jhipps835 View Post
Ok i may take a ride to the hardware store then tonight.
Here is the link, not sure if the other worked:
http://s453.photobucket.com/albums/q...t=103_7736.flv
I really couldn't tell from the vid. At some points it sounded slightly lean, but seemed like there was a good amont of smoke and it was definately four stroking some(good). As long as it is basically dripping oil from the pipe, you will be fine. IMO the richer the better for break in. You MUST keep temps around 200 using tin foil and even the head gun periodically if needed.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 08-15-2009, 04:54 PM   #21
jhipps835's Avatar
Ok thats cool. Im no where that talented either. I just dont want to ruin this engine. Ive been using the heat cycle method and right now im letting the engine cool. I just dont want to run it too lean or too rich.
Old 08-15-2009, 04:54 PM   #22
gkn0315's Avatar
Trader Rating: 126 (100%+)
I have a temp gun for sale cheap thanks and good luck
Glenn Nail
STRC LCG Slash looking for electronics
1985 Associated RC 10 Novak t4 Trinity Monster Horsepower 27T futaba Jr
gkn0315 is offline   Reply With Quote
Old 08-15-2009, 04:55 PM   #23
jhipps835's Avatar
Ok ill put some tinfoil on it. I had the 1/10th scale foam on there too. And i will slightly richen it to keep temps around 200. Thanks guys.
Old 08-15-2009, 04:55 PM   #24
Jaz240's Avatar
call a friend and borrow his temp gun
Old 08-15-2009, 04:58 PM   #25
jhipps835's Avatar
I would but there is ABSOLUTELY no one around here that runs rc. It kind of sucks but at least i will get to talk to people at the track. Hey James, do you know Goomba_7? His name is Corey Hudson and he is a terrible as well. We race at the same track so hopefully he can help out.
Old 08-15-2009, 05:35 PM   #26
1armed1's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to 1armed1
I see you have Fastlane in your signature.
Chad is running vspecs now, he can help you out if he's there.
If not, look for Sonny O'. He has a lot of time with vspecs.
Serpent,Sanwa,Fantom Racing
92zero.com,Lunsford Racing,AKA Racing
TXD Snake Skin Graphix
1armed1 is offline   Reply With Quote
Old 08-15-2009, 05:41 PM   #27
jhipps835's Avatar
Oh okay cool. Ive heard a lot about Sonny Oh.
Old 08-15-2009, 05:44 PM   #28
the factory settings on the vspec are very rich to begin with, and is ready for break in just use 20% nitro on breakin. or you could Just follow the booklet it came with.
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 08-15-2009, 06:22 PM   #29
From the video, I picked up this.
Your linkage isnt set correctly. What is happening is when you return the throttle trigger to idle/neutral, the linkage isn't set correctly so the carb is still open a bit. But when you brake the idle goes down. Use tin foil AND the 1/10 truck foam, the more heat and the richer the better for breakin. I did alot of mods so the engine would run at 225 but it was VERY rich. That's what you want for breakin. SO adjust your linkage so after you come back to idle the carb is fully closed, get a throttle return spring or ideally a rubber band/Ouchless hair band.
The engine sounds fine in the video. Pretty responsive and still blowing out smoke. What temps are you getting? I got confused on whether you have a temp gun or not. You can always do the spit test, put a little bit of water on the head and it should evaporate in a few seconds.
Losi 8ight 1.5 ~ 8T ~ XXX Buggy ~ Mini-Baja
The o''le saying goes, pay me now, or pay me later, because you gonna pay me. "Pearl_414"
Chris__RC is offline   Reply With Quote
Old 08-15-2009, 06:24 PM   #30
jhipps835's Avatar
Thanks Chris, i just got done putting one of the hairbands on there so it will do exactly what you said. Im done for today but tomorrow morning i will continue.
