Old 08-15-2009, 09:23 AM   #1
Default how to tell if your diff has to much slop??
not with shimming, with the gears themselves. i just cleaned and replaced the fluids. Now, if i hold both outdrives with one hand and turn the conical or diff housing with the other (locking the diff). I noticed one had just a tick of play while the other had a little more.
so. How much is too much? How do know when to replace the gears?
Mugen6 diffs, 5k weight, 5 gallons on them.
I obviously don't want to run it if there is a chance that it could take a dump.
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 08-15-2009, 09:45 AM   #2
Racecrafter's Avatar
Trader Rating: 25 (96%+)
You've had to question it...... So it's time to replace them.
Racecrafter is offline   Reply With Quote
Old 08-15-2009, 09:56 AM   #3
uuummmm $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
If i don't have too, i would rather not. I think if i put the s3 orings in there it should be fine you think?
Mugen
Old 08-15-2009, 04:42 PM   #4
Zerodefect's Avatar
I'm not sure what gears your talking about?
If your talking about the side gears having too much play on the spider gears inside the diff, You can put an extra shim on the spider gears. But I wouldn't, I just shim the ring and pinion.
Zerodefect is offline   Reply With Quote
Old 08-15-2009, 05:07 PM   #5
j_blaze14's Avatar
Trader Rating: 34 (100%+)
if you have thinner gaskets, start by assembling the diff (dry) with 1 gasket, it should lock or be very hard to spin. add 1 gasket at a time until there is minimal clicking by spinning both outdrives. another way is if you have an old cvd you can use as a drill bit. what i do is holding the cup use the drill in the outdrive to spin the diff internally. do it for about 30 seconds on each side, the holding the cup again and spinning one side push the other spinning out drive as hard as you can against a piece of wood (ie table, shelf) so it cuts a gauges in the wood. if the diff cuts and cuts it should be good. if it locks up the gears are too loose and need more internal shimming or less gaskets. what this does is puts force on both outdrives, not the same as actually driving, but close enough if they lock you know you have an issue. i have done this with all my diffs this year and have had no diff failures since. hope this helps.
aGama A8 EVO - Werks B2 - Sidewinder
aGama A8E - TrackStar 150a, 2560kv, 3 and 4 cell
FlySky GT3B, Turnigy HV servos, SKY Lipos
AKA, Proline, Hotbodies Rubber
Elite Performance - HORRC.com
j_blaze14 is offline   Reply With Quote
Old 08-15-2009, 06:08 PM   #6
very interesting thanx. and when you say "if the diffs lock up" do you mean it keeps the drill from turning?
Mugen
Old 08-15-2009, 06:14 PM   #7
RCmayor's Avatar
Send a message via Yahoo to RCmayor
I would just build the diff per the instructions. Most diffs are idiot proof these days.
RCmayor is offline   Reply With Quote
Old 08-15-2009, 06:18 PM   #8
last's Avatar
Someone's got to be Last
***Team Terribles***Answer RC USA/Torco Race fuel
last is offline   Reply With Quote
Old 08-15-2009, 06:20 PM   #9
Hey, I resemble that remark!
Sponsored by My Kids' Inheritance
Serpent S811 Cobra | Novarossi Plus 21-4T | Airtronics M11x | Savox Servos
mthird is offline   Reply With Quote
Old 08-15-2009, 06:24 PM   #10
its not about that. I can build them blindfolded. They have over five gallons and just want to know how much they should be wearing.
Mugen
Old 08-15-2009, 06:33 PM   #11
RCmayor's Avatar
If the internal gears look good and not severely worn just run it, worst case a diff will fail then you will have to fix it. If you are worried about it for an important race, get new internal gears. I would replace the small roll pins that key to the back of the big internal gears. I have seen those break after running for a long time. The outdrives are worn when there is a notch from the drive axle
Old 08-15-2009, 07:41 PM   #12
Davidka's Avatar
Trader Rating: 75 (100%+)
Either this is a joke or you need to throw away those Caster cars and get just about anything else.
Dreaux, stop worrying so much. Build per the instructions and keep the car clean. If the diffs or anything else is too sloppy to be worth running, it'll be obvious, you won't need to ask. It's a Mugen.
