Old 08-14-2009, 08:50 AM   #1
j8ight13's Avatar
Default LOSI 8b/8t 2.0
How many of you guys are still using the 4-shoe set-up with the 8ight b and t 2.0? I always run into the problem of those clutch pin screws stripping and im always stuck using a dremel to get them out. I don;t even over tighten them. As soon as they are snug i stop.
I wanted to know if there was a 3-shoe set up i could use instead? I heard something about using the ofna flywheel and such. Just don't know what parts i would need and what clutch bell i would be using. i have an old jammin x1-crt laying around and could just take that clutch set-up if it would work.
Thanks guys!
Team Losi/8ight 2.0-8ight-T 2.0 Hot Bodies/D8
Nova +4/ GRP MRT .21/GRP .21/GRP MRT .28/Ninja JX21/OS V-spec PROMOD
Hitec 7954HV,7955/ JR 9100s-t/ JR 8800s-t
GRP 2053, RE10, RE11, NOVA9901
DX3S/M11x
j8ight13 is offline   Reply With Quote
Old 08-14-2009, 09:26 AM   #2
cornerspeed's Avatar
Thanks guys!
I have always used the standard 4 shoe set-up. Never had a problem with the screws myself. I use a good wrench and even blue thread lock. Not sure. Maybe a better wrench hex tip? Hope you can figure it out, because the clutch set-up is awesome.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 08-14-2009, 09:33 AM   #3
Trader Rating: 29 (100%+)
i use the 4-shoe clutch setup also and havent had a problem since i got a good hex wrench..when i had a crappy hex wrench i would push the hex in the screw and put pressure on it and turn it and it wouldnt strip.
kyosho mp9:novarossi 21-4C, nova 2084, 7955TG, dx3R
slayyer is offline   Reply With Quote
Old 08-14-2009, 09:36 AM   #4
j8ight13's Avatar
don't get me wrong I do love the 4-shoe set-up. I actually narrowed it down a few mins ago. The alum. flywheel that i had to borrow from a buddy at a race had the treads stripped so it was holding down the screws. Ive never had a problem with my truggy flywheel.
I kinda wanted to use the 3 shoe just because its a lot cheaper for new clutches. 14 bucks for 2 alum clutch shoes is breaking the bank. haha.
I think im going to pick up 2 steel flywheels today and just con't to use it. I wish i knew that the flywheel threads were stripped. would have made my life a lot easier.
DX3S/M11x
Old 08-14-2009, 10:01 AM   #5
Frank L's Avatar
Trader Rating: 148 (100%+)
I have always used the 4 shoe losi setup on my 1.0 and on my 2.0 no probs. I have striped a few heads on the pins but who hasn't striped a head on a screw or 2. I like the losi setup because it is very easy to rebuild, no more busted fingers or hard spring instals. I use the king headz 6061 alum shoes on my truggy and an alum fly wheel. On the buggy same shoes but a steel flywheel to tame the bottom down a bit and make it easier to drive.
Old 08-14-2009, 10:06 AM   #6
j8ight13's Avatar
oh yeah and slayyer what plugs are you using for your jpx .21? Ive been using p3s and i think that they are to hott. I was going to try using a OD 97T or something around there. The idle would be great but it would run around 240. It only has about a gallon through so far too.
DX3S/M11x
Old 08-14-2009, 10:11 AM   #7
j8ight13's Avatar
i actually just picked up the kings head clutch shoes from a local shop for 28 for 4. They actually look like they will last a bit longer than the stock. I also am going to try the dynamite long life shoes this weekend and see how they do as well. I think im just going to stick to the 4-shoe. i love how easy it is to put shoes on. i can change all four between qualifying if i have to.
I have the hudy hex set along with the ofna and dynamite. They all work wonders. Thanks guys.
DX3S/M11x
Old 08-14-2009, 10:58 AM   #8
Two of the four clutch pin screws in my RTR flywheel got stripped out the first time i rebuilt it, but that was because i was using a crappy hex key. Since I got some decent hex drivers i haven't had that happen again.
smb3d is offline   Reply With Quote
Old 08-14-2009, 11:35 AM   #9
losiracer78's Avatar
i love the the 4 shoe clutch from losi i use the alu and the steel and never have has a prob with any of them just use a good wrench on them and you will be fine.
Screen Names Has Changed To mayhem04
losiracer78 is offline   Reply With Quote
Old 08-14-2009, 12:24 PM   #10
hey, i used to use the ofna picco plug it recomended but they were too pricy($20 a piece!) so i switched to a OS p3 and they work great!
Old 08-14-2009, 12:42 PM   #11
jrwoodchuck's Avatar
I'm on my third losi eight now and have only used the mugen 3 shoe setup on all of them and would never use anything different.
Doug
TLR 22/M-11
“Looks like I picked the wrong week to quit sniffing glue.”
jrwoodchuck is offline   Reply With Quote
Old 08-14-2009, 01:20 PM   #12
air8's Avatar
Using a standard 3-shoe clutch requires a quick change mount that can turn the top blocks around. This mounts the engine a few mm farther forward. The standard 3-shoes clutch bells are shorter length wise than the Losi bells.
I too love teh losi clutch set up. After dealing with the loctite from the factory and dremeling the clutch pins for removal, replace them with new ones, dont' use loctite, and the clutch pins do not need to be super tight. They steel pins will bind on the aluminum flywheel for some reason. So just snug is all that is needed. Oh and a good hex driver too.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 08-14-2009, 01:27 PM   #13
Integra's Avatar
Picco plugs can be had Cheap Cheap....you just have to know where to look.
I Also love the losi clutch for buggy...truggy i prefer the M2C set-up....but that's all personal preference.
Losi Truggy rcfreak24 Nitro Off-Road 1884 12-27-2009 12:53 PM
(((((losi 8b and 8t w/mucho parts , starter box and a few more extras ))))) houston R/C Items: For Sale/Trade 159 01-20-2009 10:10 PM
Losi 8ight 2.0 parts on 8ight-T TIX Nitro Off-Road 37 01-06-2009 12:57 PM
Losi 8B/8T Parts Lot rstnboy R/C Items: For Sale/Trade 7 08-22-2008 06:29 AM
Losi 8ight-T 8T with 6 sets of tires, 2 Losi 8ight-B's 8B's jsmax R/C Items: For Sale/Trade 27 06-18-2008 01:44 PM
