Old 08-12-2009, 09:31 PM   #1
Garet Jax's Avatar
Trader Rating: 91 (100%+)
Default Need help shimming my clutch/flywheel please.
First off, I am trying to prepare the Losi 4 shoe clutch that comes with the truggy race roller.
I have three questions:
1) There were two different shims provided (see picture). I know the small one goes behind the screw cap that screws into the crank shaft. Where does the big one go?
2) I am having trouble getting the bigger bearing into the back of the clutch bell. Any suggestions?
3) What is the optimal setting for shoes and springs on the Losi clutch running the werks B7 engine?
Thanks.
Need help shimming my clutch/flywheel please.-dscf3315.jpg
I am not a "Tech Master" nor even close. I simply have a lot of posts. If you want some sage advice, the only that I can give is don't listen to me.
Garet Jax is offline   Reply With Quote
Old 08-12-2009, 10:26 PM   #2
I have two questions:
Thanks.
That is 3 question, not 2.
That one goes either behind the flywheel and collet to space the clutch bell out more, or is a rubber seal from the inner clutch bearing. hard to tell from pictures.
2. Put the bearing on the crankshaft and push the clutch bell on and see if that works. I have never had any problems with that, usually the inner clutch bell falls right out.
3. Try 2 blue aluminum/2 carbon with all 4 gold springs. The B7 doesnt have alot of bottom so try running harder springs. So 4 gold or 2 green/2 gold.
Losi 8ight 1.5 ~ 8T ~ XXX Buggy ~ Mini-Baja
The o''le saying goes, pay me now, or pay me later, because you gonna pay me. "Pearl_414"
Chris__RC is offline   Reply With Quote
Old 08-12-2009, 10:32 PM   #3
Garet Jax's Avatar
I am holding up two fingers can you guess which one
I have tried a few things including WD40, but that bugger still doesn't want to go in.
Ok - I will play around with it a little.
Thanks.
Old 08-12-2009, 10:45 PM   #4
Garet Jax's Avatar
Interesting - your statement about being easy got me to try a different bearing (one I have from Answer RC) and it fit great. In fact I can't get it to stay because of the WD40 oil I put in there
Old 08-12-2009, 11:06 PM   #5
What brand bearing wouldnt fit in?
Old 08-12-2009, 11:15 PM   #6
Garet Jax's Avatar
The bearing that came with the roller from Horizon.
Old 08-13-2009, 05:50 AM   #7
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Sounds like the wrong bearing.
As for the B7 not having any bottom... depends what pipe you run. I had one with a JP-1 on it (yeah, maybe a mismatch) but it was like a light switch. Off or spinning tires.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 08-13-2009, 07:25 AM   #8
Garet Jax's Avatar
Hey Domit,
Good to see you outside of the thread from hell
It's possible I used the wrong bearing, but highly unlikely since there were only two in the plastic bag and it had the rest of the clutch pieces in there too.
I have matched it up with a 2013 on recommendation from the Werks man himself.
Old 08-13-2009, 10:52 AM   #9
Jaz240's Avatar
Trader Rating: 52 (100%+)
Sounds like you have a Killer combo almost ready to hit the track..have fun with it. I hope you get it all figured out
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 08-13-2009, 12:26 PM   #10
If that bearing won't go in all the way, it's like maroon or blue right, put it in the best you can assemble the clutch. After you tighten down the screw take everything back off and see if that worked to slide it in the rest of the way.
NitroAmmo is offline   Reply With Quote
Old 08-13-2009, 12:34 PM   #11
Garet Jax's Avatar
Tried that, but think I damaged the bearing by tightening down too tight.
Old 08-13-2009, 12:38 PM   #12
Garet Jax's Avatar
Thanks - Once the bearing went in - everything else just fell into place. The clutch /flywheel are on, the gears are meshed, the truggy is almost built and ready to go.
Yay.
