Old 08-11-2009, 05:57 PM   #1
Default question about diff oils
just want to know the mechanism behind the different weight in fluid. Like does 2,000 make the tires spin with more speed or torque? Or does 7 or 10 thousand?
what effects does different weights have on the transmission? If i can understand this i will help with the setup i want.
cause i have no idea except when someone says such and such a weight will help understeer/ oversteer etc. That is cool. but a basic understanding would be appreciated.
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 08-11-2009, 06:29 PM   #2
Buggies dont have transmissions. Download the Hudy setup book and go to diffs and that is all you will ened to know about them.
Losi 8ight 1.5 ~ 8T ~ XXX Buggy ~ Mini-Baja
The o''le saying goes, pay me now, or pay me later, because you gonna pay me. "Pearl_414"
Chris__RC is offline   Reply With Quote
Old 08-11-2009, 06:51 PM   #3
The lower the # the thinner the oil.The thinner the oil the easier the 2 tires on that diff can spin indipendintly.The thicker the oil the more the 2 wheels will be locked together up to say 100,000 in dirt they will act like a solid axle with no diff,both will spin the same speed even if one has no traction & the other is in a massive traction zone. Totaly opposite for thin oil like 1,00 in dirt the wheel with no traction will recieve all the power & balloon up like a pie plate & the one with lots of traction will do almost nothing,just sit there & not make the car move forward. Its all done by making the spider gears inside your diff have more resistance to pushing the oil out of the grooves where the teeth mesh.Thick oil is harder for one gear tooth peak to push the oil out of the other gears valley part of the teeth. Hope that helps but you still need to watch what the tires are doing from closer than the drivers stand when the car is doing something you dont like untill your used to how oil changes the handling. People will tell you this will do that but its only in general terms & you really wont be able to choose for yourself untill you just start trying different oils.Try large jumps in oil like 5,000wt at a time changes to see the difference in handling & once you get the idea of what your seing & feeling then it will be easier to zero in on what you want that diff to do.
"TEAM TERRIBLES"
butch man is offline   Reply With Quote
Old 08-11-2009, 07:16 PM   #4
thanx butch. i felt like that was it all along, but that really helped me understand. And chris i downloaded the setup book. Thanx guys.
Mugen
Grande Prairie Model Racers Association WheelNut Canadian R/C Scene 19805 06-10-2017 01:40 PM
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 05:09 AM
Mugen MBX6 teeforb Nitro Off-Road 18539 03-20-2016 02:59 PM
Losi 8ight building and setup JBRacing Nitro Off-Road 8691 06-27-2011 08:43 AM
Mugen MBX5R Nitro$junkie Nitro Off-Road 1503 04-23-2011 11:36 AM
The V-ONE baggiolee Singapore R/C Racers 362 10-15-2010 09:07 AM
