Old 08-10-2009, 10:12 PM   #1
Default OS SPEED PROBLEMS
i have an os speed with some problems. it has been flaming out excessively and i believe that is because it has an air leak at the carb the i found. not really the problem. the conrod is VERY sloppy where the bushing sits on the crank shaft. what problems could this cause besides the obvious of breaking apart inside the engine. could this be causing some of the flame out issues as well?
quicklosi is offline   Reply With Quote
Old 08-11-2009, 02:30 AM   #2
gkn0315's Avatar
Trader Rating: 126 (100%+)
How old is the speed? How many gallons?
Glenn Nail
STRC LCG Slash looking for electronics
1985 Associated RC 10 Novak t4 Trinity Monster Horsepower 27T futaba Jr
gkn0315 is offline   Reply With Quote
Old 08-11-2009, 03:18 AM   #3
By the sounds of it, your front bearing is probably leaking. Sounds like you have enough wear and tear to do. I have 4 gallons on mine and it just started leaking, so I replaced it and now it is good to go. You might want to give that a shot.
Revooooooo is offline   Reply With Quote
Old 08-11-2009, 03:32 AM   #4
blade954's Avatar
Trader Rating: 23 (100%+)
Originally Posted by quicklosi View Post
i have an os speed with some problems. the conrod is VERY sloppy where the bushing sits on the crank shaft. what problems could this cause besides the obvious of breaking apart inside the engine. could this be causing some of the flame out issues as well?
Time for a rebuild by the sounds of it
I use blue max to seal a engine if i think its that, If it continues then try bearings but that rod might have been the problem if you have had problems just recently.....
blade954 is offline   Reply With Quote
Old 08-11-2009, 05:58 AM   #5
Frank L's Avatar
Trader Rating: 148 (100%+)
If parts are wore out then time to replace them. I have had engine guys tell me to replace the front bearing every gallon or so. I replace them when they start leaking. But if the rod is slopy then it can't run right. It does not take much to flame these engines out. Rebuild it or replace the engine.
Old 08-11-2009, 05:20 PM   #6
COBRARACING's Avatar
If your having flames outs and blowing plugs you dont have a airleak what you have is a stretched conrod and if you keep on running it you will drop the glow plug element and scortch the piston and sleeve which will cost you more in repairs .
when the plugs keep on bruning out you have this extra travel in the piston movement which will eventually hit the element of the glow plug causing glow plugs to fail and in time dropping the element through your engine causing all sorts of damage piston ,sleeve,and bearings
change the Rob before it to late .
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 08-11-2009, 05:41 PM   #7
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Replace the rod and bearings. If you have not already done that once after break in, you haven't properly maintained the engine. If the carb is leaking, replace the leaky parts such as o-rings or the boot.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
O.S. Speed owner speak up NitroNewbie Nitro Off-Road 97 03-07-2010 12:37 PM
OS Speed Spec 2 Help! TBO88 Onroad Nitro Engine Zone 13 12-01-2008 06:10 PM
FEMCA 1/10th and 1/8th Onroad Championship Danny Teh Malaysian R/C Racers 152 09-07-2008 08:49 PM
WHICH IS THE BEST MODDING COMPANY?!? jatoman1992 Nitro Off-Road 21 08-28-2007 01:54 PM
OS 12 TzR romuald31 Onroad Nitro Engine Zone 1444 08-09-2007 01:50 AM
Best 12 5 Port Engine? movingparts Nitro On-Road 32 09-25-2006 11:01 AM
