engine wont start. is it the old gas?
I bought an HPI engine from a friend for 60$.
it seems like it has good compression, the glow plug is fine. but it wont start.
could it be the 8 month old nitromethane?
It probably is the fuel, was it sealed in an air tight container...
Get yourself some Nitro-X fuel, it should fire straight up, run cool and clean, with maximum runtime!!!!
not 100% sure about air tight. I was stored in a metal container with a plastic cap in the garage... sometimes when im working in the garage the metal container expands and shrinks and makes loud popping sounds.
If not da X get some fresh fuel.
yeah I had a feeling it was the gas. if not, what else could I try?
carb isint plugged, glow plug works, fuel screws are fine.
I have used 1 or 2 yr old fuel without problems. Put2-3 old large nuts in the can and shake the can so the nitro, methanol and oil will blend again.
I shook the can, mixed it up with a long screwdriver, shook it up again. filled the gas tank, blew into the exhaust hose and within 3 pulls the engine fired up. AWESOME!
I havnt driven rc cars in over a year and just got what he called "HPI big block " engine for 60$ CAD.
just need the electronics now
thanks guys
thanks guys
