Old 08-09-2009, 06:55 AM   #1
Default con rod or crank pin?
I took off the backplate of my vspec to check the rod, and noticed that there was excessive play in the rod/pin. My question is, is the play comming from the bronze bushing in the rod or is it the crank pin?
Basically do i need to replace the rod or the crank?
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 08-09-2009, 07:04 AM   #2
Zerodefect's Avatar
The rod is softer and wears faster but if its really worn it can take out the crank pin.
If its the crank pin, then you have to replace the crank, but you STILL have to replace the conrod anyway.
So I'd start with a fresh rod and test it on your old crank.
Zerodefect is offline   Reply With Quote
Old 08-09-2009, 07:09 AM   #3
thanx. How hard is it to change the rod out?
Mugen
Old 08-09-2009, 07:20 AM   #4
Zerodefect's Avatar
Its easy. Hardest part is getting the head screws out without stripping them. Push real hard before turning.
Then just be careful pulling the wrist pin spring clips out. You can't just yank them out or they'll take part of the piston with them. You have to compress or wind them up a little. I haven't got a good technique for that yet. I'll let someone else chime in on that.....
And note the orientation of all the parts. You don't want to be the guy racing a vspec with a piston in backwards (worked, but ghost flamed out. Actually seen people do this more than once )
Old 08-09-2009, 07:25 AM   #5
I am very familiar with my engine and it's parts. Just never replaced a rod. Bearings yeah. Oh piston in backwards = broken skirt. And i have never broken a head screw. I honestly don't know how people have such a problem with that. I do however replace them if they even look like they are not new. I have striped screws on the backplate though.
Mugen
Old 08-09-2009, 07:26 AM   #6
also will a hole in the carb boot act like a air leak?
Mugen
Old 08-09-2009, 08:16 AM   #7
bump for more info please
Mugen
Old 08-09-2009, 08:42 AM   #8
Zerodefect's Avatar
A hole in the carb boot is a big problem. Replace it.
I use an oring, or if that deosn't work a small zip tie at the base of the carb boot to keep it sealed. the oring is gentler and won't lift the boot like an over tightened zip tie. Doesn't work on all engines.
Old 08-09-2009, 09:35 AM   #9
smb17's Avatar
Send a message via AIM to smb17
How much play are we talking about here? how many gallons you have on it? I ran my v-spec with a pretty good amount of play in it and it seemed fine. But I don't know what your situation is =X
smb17 is offline   Reply With Quote
Old 08-09-2009, 01:41 PM   #10
22Racer's Avatar
Trader Rating: 67 (100%+)
On the Std. V-spec the crank usually wears almost as much as the rod. Best bet is to buy a Jx Ninja or Speed crank and rod, it will last much longer.
Rex
Rw modding and engine repair http://www.rw-mods.com
Sleeve resizing $15.00/ motor rebuild $30.00
Argus engine distributor/Avid bearings/ Alpha engines/
Fx Royal engines/ Maxy Engines
e-mail rwmods@yahoo.com Rex Welch
22Racer is offline   Reply With Quote
Old 08-09-2009, 01:50 PM   #11
5 gallons. and it has a good amount of play. well you can see it wobbling in there at in and around tdc. I will be getting a new ninja this week. also if you have to replace the rod and crank, bearings etc. wouldn't you be better off getting a new one? a crank and rod is about 150$$ so that would be half the price. With tko's it would be closser to 200$ so i guess if you rebuild it with a speed crank you would have a better engine anyway. i guess when the P/S go you can get a pinch or replace it.
Mugen
Old 08-09-2009, 03:32 PM   #12
22Racer's Avatar
I have pinched some friend's Speeds 3-4 times. I am not a big Os fan but the Dlc coating is awesome, only seen it worn through to silver on one motor ever. If you look for deals on Ebay I have heard of Jx cranks going for under $70.00.
Rex
Old 08-09-2009, 04:54 PM   #13
houston's Avatar
Trader Rating: 91 (100%+)
Rex
i already told him the crank usually wears before the rod on the vspecs
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 08-09-2009, 05:03 PM   #14
Zerodefect's Avatar
That stinks.
I thinks i'll be sticking with NR motors then.
Old 08-09-2009, 05:06 PM   #15
houston's Avatar
That stinks.
good choice
not bashing vspecs at all , i love the short stroke , big bore design but the cranks just wear out pretty quick .
Murnan Modified Motors Grinder Onroad Nitro Engine Zone 3797 08-07-2017 09:20 PM
Saturdays Offroad Racing in So Cal, Santa Barbara California HUGE TRACK!1 ALL CLASSES Pit Stopper California Racing 988 06-20-2017 06:44 PM
RB Concept Engine Thread.. r1harper Offroad Nitro Engine Forum 3632 06-14-2017 12:29 AM
Richey Modified Motors Snake_bit Nitro On-Road 1622 08-06-2003 07:52 PM
Collari new engine Michael_T Nitro On-Road 71 02-14-2002 07:43 AM
