Old 08-08-2009, 09:52 PM   #1
Default engine wont start. is it the old gas?
I bought an HPI engine from a friend for 60$.
it seems like it has good compression, the glow plug is fine. but it wont start.
could it be the 8 month old nitromethane?
whatsitallworth is offline   Reply With Quote
Old 08-08-2009, 09:56 PM   #2
Sam-E's Avatar
It probably is the fuel, was it sealed in an air tight container...
Get yourself some Nitro-X fuel, it should fire straight up, run cool and clean, with maximum runtime!!!!
TMORC - Official Club for the 1/10th Offroad Electric Worlds, 2012!!
Sam-E is offline   Reply With Quote
Old 08-08-2009, 10:05 PM   #3
not 100% sure about air tight. I was stored in a metal container with a plastic cap in the garage... sometimes when im working in the garage the metal container expands and shrinks and makes loud popping sounds.
Old 08-08-2009, 11:05 PM   #4
Sam-E's Avatar
Ditch that fuel and get some Nitro-X, not trying to pimp da X but seriously the fuel is probably the problem.
If not da X get some fresh fuel.
Old 08-08-2009, 11:53 PM   #5
yeah I had a feeling it was the gas. if not, what else could I try?
carb isint plugged, glow plug works, fuel screws are fine.
Old 08-09-2009, 02:29 AM   #6
MrUnlimited's Avatar
I have used 1 or 2 yr old fuel without problems. Put2-3 old large nuts in the can and shake the can so the nitro, methanol and oil will blend again.
U5 Formulaboat 1/8 hydroplane - MHZ138 AQUAMANIA - Axial Exo Terra - Tamiya Avante - LC Racing EMB1 - Atomic AMZ 4WD Touring car
MrUnlimited is offline   Reply With Quote
Old 08-09-2009, 11:30 PM   #7
I shook the can, mixed it up with a long screwdriver, shook it up again. filled the gas tank, blew into the exhaust hose and within 3 pulls the engine fired up. AWESOME!
I havnt driven rc cars in over a year and just got what he called "HPI big block " engine for 60$ CAD.
just need the electronics now
thanks guys
Old 08-14-2009, 10:18 PM   #8
Make sure the gas is getting thru the carb. Open carb and blow on pressure line and you should see fuel coming out of carb to motor. If not make sure you are not losing pressure some where and or open up top needle some more till you get fuel thru carb. Hope This helps.
bigde2001 is offline   Reply With Quote
Old 08-15-2009, 08:49 AM   #9
Byrons Gen 2 !!!!
Making a comeback !!
roadracer43 is offline   Reply With Quote
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 05:16 AM
Help! - My Teamlosi LST RC truck won't start, maybe engine broken? helgso Nitro Off-Road 61 05-26-2009 05:52 AM
NOOB to GAZ dropped_DIME Rookie Zone 15 09-05-2004 02:43 PM
