Old 08-08-2009, 06:37 PM   #1
shanty140's Avatar
Default Sealing a carb
Hey,
I believe I am going to need to seal my carb. I am unable to get my idle correct because I cannot get the idle gap down to 1mm without the engine leaning out. I think it is leaking on the idle screw.
So my question is. Do you think that this is what would cause this? If so what should I do to seal the carb up. If not what would? What is the process you guys have used? And lastly what should I be checking when taking apart the carb and reseal it up.
This is my first time ever sealing a carb and I want to make sure I am doing it right.
Race Vehicles:
Mugen MBX6T - Ninja JX.21 with EB Mods Headbutton, O.S. 2060 Pipe, DX3R, Hitec 7955TG Servos on LiPo
HPI Cup Racer - Murfdogg Synergy 17.5, Tekin RS Pro, 2S 40C 4200mah, DX3R, Savx SC-1251MG Servo
shanty140 is offline   Reply With Quote
Old 08-08-2009, 06:41 PM   #2
gkn0315's Avatar
Trader Rating: 126 (100%+)
what motor is this your talking about also you might need to replace the orings on the hight speed needle
Glenn Nail
STRC LCG Slash looking for electronics
1985 Associated RC 10 Novak t4 Trinity Monster Horsepower 27T futaba Jr
gkn0315 is offline   Reply With Quote
Old 08-08-2009, 06:58 PM   #3
shanty140's Avatar
The Losi 454 that comes with the 8ight-T 2.0 RTR
Race Vehicles:
Old 08-08-2009, 07:11 PM   #4
smb17's Avatar
Send a message via AIM to smb17
I always seal my engines. Use the lucky 7 sealer. I love it. You just put some of it down and blow it around what you're sealing and it's done.
smb17 is offline   Reply With Quote
Old 08-08-2009, 09:47 PM   #5
Integra's Avatar
i recommend a 2nd coat with lucky 7....there tends to be a few air bubble's that will pop when drying and cause a little pin hole sized hole that can/will leak through.
Old 08-08-2009, 10:34 PM   #6
smb17's Avatar
I've never had that issue. Odd. Well... maybe it's because I'm pretty sloppy with it =P
Old 08-09-2009, 02:05 PM   #7
Integra's Avatar
that could defiantly be the case....im pretty anal on stuff looking true and square.
Old 08-09-2009, 02:54 PM   #8
smb17's Avatar
Yeah I was pretty anal about the sealer. then i relized I was pretty bad at it.. There are 3 things I totally suck at.
1. gluing tires.
2. Sealing engines
3. Driving
Actually I could go on and on =P
Old 08-14-2009, 10:29 PM   #9
losi 454 has a very fine line between lean on the low needle. Minimum
1-2mm gap on opening and the tune low needle to fit.
bigde2001 is offline   Reply With Quote
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
Sealing a motor piranha21 Nitro Off-Road 61 06-20-2009 06:58 PM
T-Maxx 2.5 Over Heating! Herrick21 Monster Trucks 18 05-18-2009 09:51 AM
Engine Tuning 101 (General Tuning) Kemorc Onroad Nitro Engine Zone 41 11-19-2007 06:04 PM
Sirio .12 with Novarossie Carb -CX12 carb fit? au_Nightmare Onroad Nitro Engine Zone 10 09-25-2004 08:29 AM
