Old 08-08-2009, 11:11 AM   #1
Default os speed question
anyone know where i can buy just the thermal insulator that goes around the neck of the carb into the case? the insulator is cracked like the pinch bolt may have been over tightened at one point and it is not allowing the carb to seal. on A-mains webiste the only way to get that piece is to buy the whole carb body. any help would be very appreciated
quicklosi is offline   Reply With Quote
Old 08-08-2009, 11:52 AM   #2
gkn0315's Avatar
Trader Rating: 126 (100%+)
tower has them for 14 plus shipping part number 23781110 thermo insulator hope this help good luck
Glenn Nail
STRC LCG Slash looking for electronics
1985 Associated RC 10 Novak t4 Trinity Monster Horsepower 27T futaba Jr
gkn0315 is offline   Reply With Quote
Old 08-08-2009, 12:27 PM   #3
dont think that one will fit. according to the description of the same part number on A-mains website that part number is for the older style carband will not fit the 21j or whatever it is called that the speed uses.
does anyone know if the carb from the ninja JX21 is the same carb as the speed cuz i found a place that sells the insulator for the ninja just by itself
Old 08-08-2009, 01:08 PM   #4
gkn0315's Avatar
It the same part number for all the v pec motors what carb do you have
Glenn Nail
Old 08-08-2009, 03:49 PM   #5
i dont know what carb it is. it is a speed motor with the stock speed carb. it is the older style, not the newest one that they have with the idle screw down under neath the high speed. i thought they called it the 21J carb which is why i didnt think that isulator would fit
Old 08-08-2009, 04:19 PM   #6
gkn0315's Avatar
If it is the older speed w/ al or mag head it is the same case as the old v spec and the part number i gave you should be it also if you call os they could give you an exact answer but im pretty sure there the same the only differance between the v spec and the speed was the head , crank and piston sleeve and rod hope this helps good luck
Glenn Nail
Old 08-08-2009, 04:24 PM   #7
gkn0315's Avatar
Here is os tech support give them a call 1-217-398-8970. Available Monday-Friday, 8am-5pm U.S. Central Time.
Glenn Nail
O.S. .12 TZ(P)-T3 Speed Tuned madnitro Onroad Nitro Engine Zone 368 04-07-2013 11:17 PM
os speed question quicklosi Nitro Off-Road 10 07-29-2009 07:41 AM
Question on O.S. Speed's jamiekerr14 Nitro Off-Road 56 06-22-2009 08:26 PM
Which engine? gnpower Nitro Off-Road 7 06-17-2009 07:17 AM
OS Speed V-Spec II question Frank L Nitro Off-Road 32 05-20-2009 10:50 PM
OS SPEED FUEL QUESTION HAWK498 Nitro Off-Road 6 01-04-2009 05:06 PM
c6,os speed,go modded Ultraspeed84 Nitro Off-Road 59 08-18-2007 08:04 PM
