Old 08-08-2009, 08:49 AM   #1
Default Losi 8ight T 2.0 shock ends
my frist day with my 8ight T 2.0 i lost a shock end on the rear shock. then i have noticed it is a pretty common thing due to the new longer shafts.. is there any mod to stop this from happing?? In last weekends a main i would say 5 out of 7 2.0T's lost the rear shock end
Ray's Hobbies
8ight 2.0/Novarossi Plus-4
8ight 2.0T/Novarossi Plus-4
HAWK498 is offline   Reply With Quote
Old 08-08-2009, 10:06 AM   #2
Integra's Avatar
Did you and the 5 others check the shocks prior to running them ? they are stripped from the factory and require a little attention before they can be 100% trusted.....I've never once pulled a shock end off any of my losi's and in the very beginning i NEVER used to set droop as i didn't like the screw's gouging a home in the chassis....so i have 100% travel on my shocks and did that for over a year and never lost one.
Old 08-08-2009, 04:52 PM   #3
Unsober1's Avatar
This is a manufacture issue. They were all stripped from the factory. Even though it is a race roller. I prefer kits. A good suggestion is to take it apart and rebuild it to YOUR liking before ever running thr truck. Also you will find some issue with screws being too short and not seating into the nylon in the nut. If you ran truck box stock for a bit, you already know what I am talking about
Unsober1 is offline   Reply With Quote
Old 08-08-2009, 07:33 PM   #4
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
just lost my 1st end in the main 2day. still managed to finish. tough buggy indeed.
R
UltegraSTI is offline   Reply With Quote
Old 08-08-2009, 10:10 PM   #5
Like Integra said some of the shock ends come stripped from the factory. All you need is new shock ends and check your droop screws to make sure the shock length is set right and the problem will be solved.
*Team Losi Racing*Team Orion*Nitrotane*Airtronics*Spektrum*UpGrade RC*RCiD*
Clint Wachter is offline   Reply With Quote
Old 08-08-2009, 11:19 PM   #6
markt311's Avatar
Trader Rating: 32 (100%+)
My buddies 8 T 2.0 had a shock end that had pulled off in the box. This was about 3 months ago, so maybe after that run of rollers Losi fixed the problem. I would still replace all the shock ends before I ever run the truck. Contact Losi and they will send you some new ends to put in your box for spares. Another reason I like to build them myself.
PR Racing Bellgate Distributors
Caster Racing Parts
311 RC Graphics
markt311 is offline   Reply With Quote
8ight 2.0 vs 808 vs O'Donnell jpas Nitro Off-Road 66 10-14-2008 09:31 AM
What buggies RCTECH users own... Edron Nitro Off-Road 37 11-25-2007 03:32 PM
