Old 08-07-2009, 09:30 AM   #1
gangstzer's Avatar
Send a message via AIM to gangstzer Send a message via Yahoo to gangstzer
Default HELP PLEASE!!!
Ok hey i just installed a new jr high torque steering servo in my jato. For some reason the servo wont turn the wheels at all in both directions and only in 1 direction. ( meaning I cant turn left and right but only left ). I have tried to tweak my remote to controll the servo but it seems as if its not working. Any advice? Its really pissing me off this 70 bux servo is freaking up!
http://www.rctech.net/forum/r-c-items-sale-trade/317150-gas-powered-blowout-electrics-come.html#post6157746
gangstzer is offline   Reply With Quote
Old 08-07-2009, 09:40 AM   #2
KThatcher's Avatar
Trader Rating: 64 (100%+)
Try reseting the horn.. take it horn off turn car on and then put the horm back on making sure tires are zeroed
- Picco - Triton RC - 818 Designs - Team-CRP - RCRenew.com -
Pro Motion T-shirts -
KThatcher is offline   Reply With Quote
Old 08-07-2009, 09:45 AM   #3
scwrod's Avatar
your request is confusing but I will try.
New steering Servo Install-
Zero out any steering trim on the RX.
Install new servo with no horn.
Turn on Radio and then the RX
Servo will be centered.
Attach servo horn with wheels as straight as you can (RX still on).
Last thing is to check steering EPA and make sure there is no unnecessary strain on the servo!
P.S. If the servo is a different brand you may need a new horn that will match the new JR servo.
What servo was in it before???
hbracing.com tritonrc.com raceaka.com
scwrod is offline   Reply With Quote
Old 08-07-2009, 11:53 AM   #4
Hi there, ok, you need to center the servo, remove the servo horn with the electronics turned off, then turn the radio and car on. then re install the servo horn. also double check your radio's end points. good luck and have fun at the races. Scott
rc_racer1 is offline   Reply With Quote
Old 08-07-2009, 02:34 PM   #5
gangstzer's Avatar
ok I did that...no new results...its not turning the wheels strong enough to the left or the right now...
Old 08-07-2009, 02:40 PM   #6
pyromania's Avatar
Trader Rating: 18 (100%+)
Did you change the servo spline?
Jesse Carrillo
Team Driver For:
TLR | Horizon Hobby | Nitrotane | Spektrum | HandleITHobbies | 818 Designs
pyromania is offline   Reply With Quote
Old 08-07-2009, 02:48 PM   #7
Jaz240's Avatar
Trader Rating: 52 (100%+)
Servo saver set too lose???? tighten down that bad boy!!
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 08-07-2009, 02:58 PM   #8
Madbrad's Avatar
Trader Rating: 29 (100%+)
Take the servo horn off and then turn on your radio and turn the wheel and see if the servo moves. If it does then the servo is not the problem. Next make sure that the inside of the servo horn is not striped out. It may fit on there but if all the groves are gone it wont turn.
XT8 - Werks B5
Hyper 10SC Novak PRO ESC 4.5HV
Madbrad is offline   Reply With Quote
Old 08-07-2009, 03:01 PM   #9
Trader Rating: 67 (100%+)
Is this servo digital? If so, it may not work with your current radio system. You didn't give any details so it is difficult to know what you had in the truck. Could be the stock Traxxas or maybe you swapped it out for another brand as one of the other posters suggested.
nutz4rcyktw is offline   Reply With Quote
Old 08-07-2009, 03:02 PM   #10
JeromeK99's Avatar
If you are using the stock Traxxas radio, make sure that the servo you bought is "digital".. if its an analog.. you won't be able to use it... I've seen this happen with Slash and Slayer owners...
Jerome
JeromeK99 is offline   Reply With Quote
Old 08-07-2009, 07:02 PM   #11
gangstzer's Avatar
yea its a digital servo and im not using the stock remote. Im using the jr xr2..
Old 08-07-2009, 07:08 PM   #12
when you take the horn off, and turn the radio on does the servo move then without the horn?
this may sound silly but you didn't plug it into the throtle did you? are your batteries fully charged?
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 08-07-2009, 11:02 PM   #13
gangstzer's Avatar
no, no, yes
Old 08-07-2009, 11:48 PM   #14
JeromeK99's Avatar
Then maybe its the opposite.. Can the JR XR2 handle digital servos?
Jerome
Old 08-08-2009, 11:47 AM   #15
gangstzer's Avatar
its a digital remote.....
