Old 08-06-2009, 11:37 AM   #1
Trader Rating: 29 (100%+)
Default thinking the motors shot!
this past weekend at our club race my motor cut off in the main and i could never get it started again. i can start it now but ONLY if i hit the trigger and givew it throttle, as soon as i let go and it idles, it cuts off. any ideas of what might be wrong? the compression is pretty bad also but wasnt bad at all before the race i went to. the motor only has 3 gallons through it and hasnt run over 240 EVER!
kyosho mp9:novarossi 21-4C, nova 2084, 7955TG, dx3R
slayyer is offline   Reply With Quote
Old 08-06-2009, 11:53 AM   #2
losiracer78's Avatar
Have you changed out the glow plug. I would check that first.
Screen Names Has Changed To mayhem04
losiracer78 is offline   Reply With Quote
Old 08-06-2009, 12:17 PM   #3
halfman's Avatar
try sealing the engine too
Sponsors: Xray, RC America, Novarossi, Indy RC World Paint by RJ, Vp Racing Fuels, SPD Mods, Avid Bearings, Desoto Racing, Speed monkey Batteries
halfman is offline   Reply With Quote
Old 08-06-2009, 12:48 PM   #4
Akhor's Avatar
Did it hit it's breakin point and just need to be re-tuned?
--Blaine--
VBC D07, VBC D08
Mugen MBX 7, Mugen MBX 7 Eco,Mugen MBX 7r, Mugen MBX 7r Eco
www.rcgears.net, www.carcar.ca, www.karz.ca
Akhor is offline   Reply With Quote
Old 08-06-2009, 01:22 PM   #5
+1 retune......
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 08-06-2009, 01:25 PM   #6
change the plug and retune
Old 08-06-2009, 01:36 PM   #7
midwestcajun's Avatar
Think you should sell it. I'll take it off your hands for cheap
Seriously sounds like a tuning issue though..if you said it dies when it gets hot I would think otherwise. Usually that's a compression issue. Idle up and see where you get. Also you might have to fumble with the low end.
~Tyler Watson~
midwestcajun is offline   Reply With Quote
Old 08-06-2009, 02:25 PM   #8
houston's Avatar
Trader Rating: 91 (100%+)
check plug, replace if bad , turn your idle up to get it running and retune the engine .
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 08-06-2009, 02:36 PM   #9
If anyone would know it would be Monty the Great Motor Man
Old 08-06-2009, 04:47 PM   #10
its leaking oil and gas out of the bottom of the head and going up the button and leaking out..would that be a busted shim?? or a button issue?
Old 08-06-2009, 05:25 PM   #11
BUMP, any help?????? would be greatly aprecieted!
Old 08-06-2009, 05:33 PM   #12
If it still has some commpresstion? tear it down,clean it up, seal it up, re-set it to break-in settings and go. Take a close look at the o-rings on the needles, and fresh fuel lines, new glo-plug, and you should be all set. Or just break out 2-3 hundred and buy a new one. Me, I always go cheep first,then blow the flow. Or you could send it to one of the motor guys on here and let them do it.
The Working Man is offline   Reply With Quote
Old 08-07-2009, 02:11 AM   #13
Trader Rating: 27 (100%+)
take the motor apart.. its ez
and just go over everything
spawn_x is offline   Reply With Quote
Old 08-07-2009, 06:40 AM   #14
Madbrad's Avatar
Have you checked to make sure they are tight? Screws do find away to come loose.
XT8 - Werks B5
Hyper 10SC Novak PRO ESC 4.5HV
Madbrad is offline   Reply With Quote
Old 08-07-2009, 08:26 AM   #15
houston's Avatar
loose head or plug most likely
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 05:16 AM
Tamiya DF-03 type tom_chang79 Electric Off-Road 1048 01-17-2016 09:06 PM
BANZAI Motors Eddie Garrison Team and Company Discussions 11666 09-09-2015 12:43 PM
WCIC '06/'07 grabber Canadian R/C Scene 984 07-05-2007 10:55 PM
Surrey Smack talk. (that's oval racing by GOD!) Bob-Stormer Minnesota and North/South Dakota Racing 19 04-06-2007 06:49 AM
Would Wisconsinites have an advantage in the Tamiya Worlds? Leester-111 Racing Forum 18 06-28-2005 12:12 AM
