Old 08-07-2009, 08:32 AM   #16
reggie l.'s Avatar
240 isnt that hot...btw
_ClockWork-Racing_
http://www.clockworkracingengines.com/
~8t 2.0
~MUGGIFIED Lst-xxl
reggie l. is offline   Reply With Quote
Old 08-07-2009, 11:06 AM   #17
Trader Rating: 29 (100%+)
yea i know how to take a motor apart. you have to know how to do that! i cleaned it all up and now i got it to idle!
kyosho mp9:novarossi 21-4C, nova 2084, 7955TG, dx3R
slayyer is offline   Reply With Quote
Old 08-07-2009, 11:08 AM   #18
any btw reggie, for my motor i have, i run it 230-240 becuase the manuel says dont run it over 250..
Old 08-07-2009, 11:14 AM   #19
reggie l.'s Avatar
for the 3/3? if im not mistaken your not in risk unless you run past 275-280 and if the motor runs good and has a good trail of smoke down worry about the temp tim roberts says he runs his 3.3 some time on a hot day at 300 but its good so dont worry about the temp bro it can handle more than that
_ClockWork-Racing_
~8t 2.0
~MUGGIFIED Lst-xxl
Old 08-07-2009, 11:23 AM   #20
Trader Rating: 52 (100%+)
this past weekend at our club race my motor cut off in the main and i could never get it started again. i can start it now but ONLY if i hit the trigger and givew it throttle, as soon as i let go and it idles, it cuts off. any ideas of what might be wrong? the compression is pretty bad also but wasnt bad at all before the race i went to. the motor only has 3 gallons through it and hasnt run over 240 EVER!
I would actually guess it as a couple things.
sounds like the temps came up (although 240 isnt bad) due to the loose head bolt.
the idle drop could have been to the heat most of the time when a motor warms up the idle drops some.. or also could have been from a dirty air filter, that will also cause the idle to drop.. typically if you run a motor for a good qualifyer and then set the idle you should be good for a loooong time before having to change that..
just my opinion anyway.
MO
Mo Denton-www.mnkraceway.com
Team Losi
Proline,-Redrock Hobbies-,VP Powermaster fuel,Darkside Designs,Speedy Bills!
fast for an old guy
Mo Denton is offline   Reply With Quote
Old 08-07-2009, 11:33 AM   #21
Cory Kerber's Avatar
The same thing happened to me when my piston skirt was broke.
Cory Kerber is offline   Reply With Quote
Old 08-07-2009, 06:10 PM   #22
no reggie, its a jammin .21 in my buggy.
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 05:16 AM
Tamiya DF-03 type tom_chang79 Electric Off-Road 1048 01-17-2016 09:06 PM
BANZAI Motors Eddie Garrison Team and Company Discussions 11666 09-09-2015 12:43 PM
WCIC '06/'07 grabber Canadian R/C Scene 984 07-05-2007 10:55 PM
Surrey Smack talk. (that's oval racing by GOD!) Bob-Stormer Minnesota and North/South Dakota Racing 19 04-06-2007 06:49 AM
Would Wisconsinites have an advantage in the Tamiya Worlds? Leester-111 Racing Forum 18 06-28-2005 12:12 AM
