Old 08-05-2009, 02:44 AM   #1
dishsoap's Avatar
Default Alternative Plug Choices For the Nova .21 Limited
With some recommedations I am planning on buying the Nov .21 3 port limited for my son. His mach RTR is finally toast and will not hold a tune and will not stop flamming out.
From what people have said this engine is easy to tune never flames out and has enough power for mostly everything.
Will this engine only take a Nova #6 plug or can another manufacture be used. If so what plug would you recommend other than the nova #6.
I will be using an 086 pipe on it since I already have one.
Thanks everyone.
HobbyTown USA Tucson!!! HobbyTown USA SRS!!!!
dishsoap is offline   Reply With Quote
Old 08-05-2009, 03:14 AM   #2
losi_racer's Avatar
Trader Rating: 25 (100%+)
i would recommend a nova plug, monty says a od plug works ok to.
i tried other plugs on my +4 and it just didnt work, even had casey peck tune it
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 08-05-2009, 05:39 AM   #3
losiracer78's Avatar
the nova rossi n21bf is a little monster and will run well on the od plug thats what i ran in mine for 11 gals until i bought the + 4. Great motors and you can get one from Manty for like 200.00 modded.
Screen Names Has Changed To mayhem04
losiracer78 is offline   Reply With Quote
Old 08-05-2009, 06:17 AM   #4
Trader Rating: 4 (67%+)
I personally run the od 77 in mine and it runs great! No flame outs and makes great power. Plus I can get 2 of these plugs for what 1 nova plug cost.
Hot Bodies D8-future home of a novarossi plus 4(courtesy of H.E.S.and Monty)-DS1015-spektrum dx3r/Team Terribles
Shane369 is offline   Reply With Quote
Old 08-05-2009, 06:26 AM   #5
unsp0ken's Avatar
Trader Rating: 24 (100%+)
odo 77
unsp0ken is offline   Reply With Quote
Old 08-05-2009, 06:29 AM   #6
+ 1 on the od 77 plug
Old 08-05-2009, 09:38 AM   #7
wingracer's Avatar
Trader Rating: 23 (100%+)
I hear OD plugs work but haven't tried them. I can tell you that Sirio plugs are FANTASTIC in Nova motors.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 08-05-2009, 09:40 AM   #8
unsp0ken's Avatar
eek... don't sirios have different taper from nova and odo plugs?
Old 08-05-2009, 09:49 AM   #9
wingracer's Avatar
Every plug out there has a slightly different taper. Some still work well, some sort of work, some don't work at all. For example, never run a Nova plug in an OS. It will leak.
Nova motors dominate onroad racing but their plugs aren't anywhere near as good as they used to be so most onroad racers have been trying other plugs. GRP's seem to be the best of the ones that fit well but they are getting hard to find. Sirios fit flush, don't leak, perform beautifully and last ten times longer.
It's kind of odd that Sirio plugs fit so well because if you go the other way and put a Nova plug in a Sirio, the plug doesn't quite go all the way flush. It sits up above the chamber just a bit but still runs fine and doesn't leak.
Team Shepherd USA
Old 08-05-2009, 09:53 AM   #10
8&stuff's Avatar
Trader Rating: 55 (100%+)
when running standard buttn i had best luck with odo97 or 99personally i wouldnt run anything else in a bf2000
Thanks everyone.
Mark Buecker
8&stuff is offline   Reply With Quote
Old 08-05-2009, 11:50 AM   #11
Trader Rating: 30 (100%+)
I've been running MC-8's in mine on 30% Sidewinder. About 2.5 gallons on it and it's really starting to come around. Awesome budget engine. The 086 will help out your top-end, which is really the only area that engine lacks. Should rip!!!
sdtech58 is offline   Reply With Quote
Old 08-05-2009, 02:02 PM   #12
Odonnel #100
Making a comeback !!
roadracer43 is offline   Reply With Quote
Old 08-05-2009, 02:46 PM   #13
Od plugs seem to work very well for me as well in all my motors nova 21-4 and both my nova n21bf's .
Old 08-05-2009, 02:57 PM   #14
dishsoap's Avatar
Would everyone agree that this is a very durbale, easy to tune, never flamming out engine.
Old 08-05-2009, 03:04 PM   #15
smittyusmc's Avatar
MC #59 or #8 med best plug for that motor I ran that motor for my spring series and took second over all and I have these plugs the hole time I could run to weekends on one plug no problem.
Hot Bodies Hara D8 - ODss .21
Team Associated B4.1 reedy 8.5, R10 Pro
Team Associated T4.1 OHP 17.5, Tekin RS
Team Associated B44.1 reedy 6.5, R10 Pro
smittyusmc is offline   Reply With Quote
