Old 08-04-2009, 12:44 PM   #1
jhipps835's Avatar
Trader Rating: 13 (88%+)
Default Flywheel nut help!
Hey guys i just sold a motor and im trying to get the flywheel nut off but when i put it on i used locktite and now i cant get it off. It will turn but it doesnt look like its coming off. Any tips on how to get it out easier? Any input would be nice.
Losi 8ight 2.0 - O.S V-Spec - Futaba - AKA - M8 - Spektrum - Byrons 20%
jhipps835 is offline   Reply With Quote
Old 08-04-2009, 01:10 PM   #2
jhipps835's Avatar
Anyone??? I really need to get this off. Would wd40 do anything?
Old 08-04-2009, 01:20 PM   #3
Use a heat gun on the nut, the heat will break the loctite free.
USP45 is offline   Reply With Quote
Old 08-04-2009, 01:21 PM   #4
unsp0ken's Avatar
Trader Rating: 24 (100%+)
are you sure you're not turning the crankshaft along with the nut?
unsp0ken is offline   Reply With Quote
Old 08-04-2009, 01:27 PM   #5
wallot's Avatar
use piston locking tool to lock the crankshaft, heat the pinion well and it should go off. then flywheel removal tool to take off the flywheel.
DEX408 - Speed Passion Silver Arrow v2, LRP Dynamic 8
Dex410 V3 - Tekin RS Pro, 7.5t Redline
F1-09 - Tekin RS Pro, 17.5t Redline
Sakura Zero S - LRP Quantum, Saturn 20T
KoPropo Eurus
wallot is offline   Reply With Quote
Old 08-04-2009, 01:29 PM   #6
you need to get a ROD lock, I dont agree with any other way - but some people uses toothbrushes or zip ties through the rear....
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 08-04-2009, 01:32 PM   #7
jhipps835's Avatar
Yes the piston is turning when i try to unscrew to nut. What should i do?
Old 08-04-2009, 01:34 PM   #8
losi_racer's Avatar
Trader Rating: 25 (100%+)
read the responses they already told u
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 08-04-2009, 01:39 PM   #9
jhipps835's Avatar
I got it thanks guys!!!
Old 08-04-2009, 01:40 PM   #10
unsp0ken's Avatar
just don't use the piston lock tools that go in the glow plug hole and don't stick anything in the rear exhaust.
Old 08-04-2009, 01:42 PM   #11
jhipps835's Avatar
Now how do i get the collet off?
Heat that up too?
Old 08-04-2009, 01:43 PM   #12
Heat that up too?
I just use a pick right in the crack
Old 08-04-2009, 01:43 PM   #13
unsp0ken's Avatar
you see that slot/slice on the collet? get the smallest/thinnest flat head screwdriver you can find and stick the head in the slot/slice to force the collet to open up.
Old 08-04-2009, 01:45 PM   #14
I would not use a piston locking tool. It could damage the piston. If I have that problem, I pull the back plate and use a pair of needle nose pliers and a small rag to hold the conrod. Or you can put a zip tie thru the exhaust port to keep the piston from moving.
Shaun Davis
VP ProUSA
Mugen Seiki/Alpha Engines
Team Trinity
Miniracer23 is offline   Reply With Quote
Old 08-04-2009, 01:47 PM   #15
http://www.amainhobbies.com/product_...ing-Tool-12-21
this is the best thing you can use, i would not use pliers - thats me
Kyosho VoneR Thread neons Nitro On-Road 12206 06-29-2012 03:19 PM
centax clutch ? HELP ! carpet_killa Nitro On-Road 60 10-13-2011 05:38 PM
Team Orion CRF Wasp Rev X-Dyno results Nano Onroad Nitro Engine Zone 1531 11-07-2010 01:43 AM
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 01:47 PM
HELP...RPMs very low beers4evo Nitro On-Road 23 01-20-2009 07:07 PM
Fioroni twin turbo issues. Larks Nitro Off-Road 9 08-27-2008 12:35 PM
