Old 08-04-2009, 12:05 AM   #1
Amoeba's Avatar
Send a message via AIM to Amoeba Send a message via MSN to Amoeba Send a message via Yahoo to Amoeba
Default V-Spec fuel consumption tweaking
I searched through the threads but for the life of me couldn't find any discussion on this. Apologies if this is a dupe thread topic.
I'm running a V-Spec with the red 8mm restrictor and a JP-3 pipe on my RC8 with Torco 30%. I'm very happy with the performance as it stands but am looking to get more run time per tank. In 30min mains I'm pitting 5 times (6mins). I could go with 4 pits (7.5mins) but I'm running on a *very* long track and I'm right on the edge. I want to increase the runtime buffer a bit so I can drop the number of pits without having to worry about pushing my luck.
Do I move to a 7mm restrictor and/or look at a different pipe? If pipe, what ones in particular would give the best bang for the buck in terms of extending run-time without being too far off from my existing V-Spec/JP-3 setup in terms of performance & powerband?
Erin Carroll
Do Not Taunt Happy-Fun Ball
Amoeba is offline   Reply With Quote
Old 08-04-2009, 12:55 AM   #2
imaxx21's Avatar
Send a message via AIM to imaxx21
JP3 is a fuel hog, get the Losi RE11 or OS 2050
and a 7 will help, you'll still have plenty of power
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 08-04-2009, 06:52 AM   #3
+1
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 08-04-2009, 07:08 AM   #4
Frank L's Avatar
Trader Rating: 148 (100%+)
I run an os speed which is just a high end vspec a 2060 pipe and an eb mods head button with 6.5 to 7 restrictor. I am getting 10+ min of runtime on a very large track. I would try the 7 or even 6.5 restrictor first it's cheapest. Then pu the eb mods head button in it hosts power so you are not on the throttle as much. You can get them at tonysscrews.com. Last get a 2060 pipe it's smooth and great on gas. I still have tons of power low and lots of top end when it winds up. I think you could easily get 8-8.5. It may also require a little trigger control. Good luck
Old 08-04-2009, 11:12 AM   #5
imaxx21's Avatar
i run a 6mm in my speed
i was at Rev saturday and had plenty of power everywhere
-Crash
Old 08-04-2009, 12:30 PM   #6
losi_racer's Avatar
Trader Rating: 25 (100%+)
i used to run a jp3, my mileage was great, i was getting 8 min a tank w/ 8 mm res.
Im using a 2035 pipe now w/ 7 mm res and i havnt done my tests for milage but at 7 30 i still have a 1/3 of a tank
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 08-04-2009, 12:35 PM   #7
imaxx21's Avatar
so that 8min from before wasn't all that great after all?
-Crash
Old 08-04-2009, 02:01 PM   #8
I've seen a v-spec with a 6mm venturi and a JP-2 go 11 min. Keep in mind to be smooth on the throttle as well. Makes a huge difference.
Shaun Davis
VP ProUSA
Mugen Seiki/Alpha Engines
Team Trinity
Miniracer23 is offline   Reply With Quote
Old 08-04-2009, 02:09 PM   #9
losi_racer's Avatar
but i also went down in res when switchin pipes, 8 min was fine, unless i can get 10 min a tank im pitting twice regardless at my track, i may be able to get 10 with my setup now idk, latley its been raining so ive been having to play with tune so i havent been able to do a good test,
Old 08-04-2009, 02:46 PM   #10
jrwoodchuck's Avatar
+2
i use the re-11 and love it. i had the jp-3 and i was shocked at the increse in run time when i went to the re-11, plus i lost no power.
Doug
TLR 22/M-11
“Looks like I picked the wrong week to quit sniffing glue.”
jrwoodchuck is offline   Reply With Quote
