Old 08-03-2009, 11:39 PM   #1
dishsoap's Avatar
Default Servo or Radio Settings
I am running an M11 and Hitec 7955 servos.
I have a slight problem that I never noticed until a fellow racer pointed it out to me this past weekend.
I always turn my buggy off first and then the radio. Well it just so happend that while I was getting help replacing a part we noticed that when I turn the radio off first the servo goes into full throttle. It does this automatically.
It dawned on me that if I ever lose radio signal I could have a big problem on my hands. It only does this if I turn the radio off first but not the other way around.
We re programmed the radio to sync the reciever again and can not figure out why this is happening.
Any thouhts.
HobbyTown USA Tucson!!! HobbyTown USA SRS!!!!
dishsoap is offline   Reply With Quote
Old 08-03-2009, 11:51 PM   #2
pyromania's Avatar
Trader Rating: 18 (100%+)
Any thouhts.
When you bind the receiver to the radio, do you hold the trigger to the brake position?
Jesse Carrillo
Team Driver For:
TLR | Horizon Hobby | Nitrotane | Spektrum | HandleITHobbies | 818 Designs
pyromania is offline   Reply With Quote
Old 08-03-2009, 11:53 PM   #3
Jaz240's Avatar
Trader Rating: 52 (100%+)
what Jesse said!! your failsafe is set to full throttle instead of full brake..easy fix, just rebind at full brake
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 08-04-2009, 12:10 AM   #4
dishsoap's Avatar
Yes
And Yes
Still wont set right. Maybe I should pull out the instruction book and try it again.
Old 08-04-2009, 05:43 AM   #5
Before resetting fail safe check if you have your servo reversed in your settings also.
jbusaf is offline   Reply With Quote
Old 08-04-2009, 05:56 AM   #6
Jaz240's Avatar
Wooaaaa, woooaaaa...nobody asked you to pull anything out!!! that's just gross
Old 08-04-2009, 06:01 AM   #7
make sure you servo is reversed before you rebind
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 08-04-2009, 06:13 AM   #8
Frank L's Avatar
Trader Rating: 148 (100%+)
I would suggest rebonding at neutral or slight brake not full brake. If the failsafe engeges and it's set at full brake the car will come to a screeching hault and prob get smashed by other cars on th track. At slight bake or nutral it will coast to a stop and or off the track. The othe. Prob with full brake is when the car is on and the radio off the servo will sit there and strain to hold full brake, not the best position fir the servo to stay in for awhile. Just a thought.
Old 08-04-2009, 04:23 PM   #9
+1 I had my father pitting for me during a race and he forgot to shut off my receiver after my race. My failsafe was set to full brake. Ended up frying my brand new 7965. I've set failsafe to neutral since then.
Shaun Davis
VP ProUSA
Mugen Seiki/Alpha Engines
Team Trinity
Miniracer23 is offline   Reply With Quote
Old 08-04-2009, 04:28 PM   #10
losi_racer's Avatar
Trader Rating: 25 (100%+)
i was havin a lot of issue with my old radio with failsafe, luckly didnt burn out any servos but since then i just put it to neutral,
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 08-04-2009, 04:29 PM   #11
fatdaddy's Avatar
+2 i did the same thing. i turned my radio off and not my receiver, and i fried my throttle servo, and damn near caught my car on fire
i also set my failsafe to neutral after this
HPI Racing - Hot Bodies - D8 Army!
**Team Terribles** (Answer RC, Fastlane Graphix, Caster racing, M2C Racing, and Dialed Inc!)
fatdaddy is offline   Reply With Quote
Old 08-04-2009, 04:55 PM   #12
jazjato's Avatar
Just adding more of the same fail safe to neutral with rubberbands as a return on the carb I've lost a couple servos running off to marshal and leaving the car on after turnng the radio off.
Team Terribles
jazjato is offline   Reply With Quote
Old 08-04-2009, 06:45 PM   #13
Integra's Avatar
i set mine to 1/4 brake....or barely grabbing if anything.
Tamiya TA05 Touring Sedan kentech Electric On-Road 11403 06-21-2017 03:10 AM
RC FLIGHT brading Manila Racers 23110 12-24-2015 06:23 PM
Fuel Injection?!?!? vtl1180ny Nitro On-Road 25 10-17-2013 02:53 PM
Mugen MTX-3 university_dave Nitro On-Road 17237 12-30-2012 12:16 PM
servo noise...normal? beers4evo Nitro On-Road 9 03-19-2011 07:19 PM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 01:50 PM
How I threw away 6-months of racing rayhuang Electric On-Road 38 04-23-2006 09:53 PM
