Old 08-03-2009, 06:38 PM   #1
Default front engine bearing
is it ok to spray behind the flywheel with wd40 to keep the bearing clean?
while i am at it. Are ready rollers good clutch bearings? My LHS carries patriot rc which is garbage but 2 clutch bearings is like 5$$ what a joke!
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 08-03-2009, 06:51 PM   #2
imaxx21's Avatar
Send a message via AIM to imaxx21
use break cleaner or nitro spray
yes they are good bearings
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 08-03-2009, 07:05 PM   #3
I thought brake cleaner was bad for bearings? it's ok to spray behind the flywheel with it?
Doesnt matter right now anyway. just noticed my carb boot has a small hole in it.
Mugen
Old 08-03-2009, 08:10 PM   #4
8&stuff's Avatar
Trader Rating: 55 (100%+)
iv always used brakleen to help loosen up heavy grease in clutch bearings. then sometimes add a little medium bearing lube
Mark Buecker
8&stuff is offline   Reply With Quote
Old 08-04-2009, 06:07 AM   #5
losiracer78's Avatar
the bearings that come with most kits are ok. You can order some bearings from Avid bearings for a buck each and there alot better then the ones in the kit and you can just throw them out when they start to get rough and not worry about wasting money.
Screen Names Has Changed To mayhem04
losiracer78 is offline   Reply With Quote
Old 08-04-2009, 11:55 AM   #6
Peter Martin's Avatar
Better to use the WD-40 or a citrus spray cleaner. Nitro and brake cleaners dry out and help shrink the rubber seals...not what you want.
Peter Martin is offline   Reply With Quote
Old 08-04-2009, 12:06 PM   #7
omarwashington's Avatar
+1 Since the front bearing is rubber sealed I wouldn't use brake/nitro cleaner. Even tho it says non chlorinated I still will not use it on o-rings, plastics or rubbers just to be safe.
RCCARS!
omarwashington is offline   Reply With Quote
Old 08-04-2009, 02:06 PM   #8
Best deal for any bearing is Amainhobbies ProTek. They make just about every size you would need.
Shaun Davis
VP ProUSA
Mugen Seiki/Alpha Engines
Team Trinity
Miniracer23 is offline   Reply With Quote
Kyosho VoneR Thread neons Nitro On-Road 12206 06-29-2012 03:19 PM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 07:19 AM
2nd cracked case.. engine mount problem. any suggestions? builtb16a Nitro Off-Road 39 08-15-2009 12:44 AM
Mugen MTX-2 tekrsq Nitro On-Road 2839 10-15-2006 08:09 PM
