Old 08-03-2009, 01:46 PM   #1
casterdriver's Avatar
Cool FUEL MILEAGE................
OK we all have the guy at the track who gets 10+ minutes w/30% fuel)under race conditions but he is super smooth and kicks our asses every week.....SOOOOOOOOOO for us other 99% that are throttle junkies and cant get any more than 7-8 minutes on a good day. What about running LOWER nitro %(10-15% is what I am thinking), dropping the deck height WAY down and running a hot ass plug a.k.a.OS P3/LC3 or equivalent to keep a decent idle/bottom end cleaned up . thats my thoughts... what are yours........ I am talking OS V-spec, JX-21, etc...
Mugen MBX7/WERKS CRE-B6,Stock B6,Stock B2/Werks 2013,2057,2058
RC10GT2-FT, Dynamite Platinum .12
VP-Racing Powermaster 20% and 30% Race Fuel
Official NON-EXPERT
casterdriver is offline   Reply With Quote
Old 08-03-2009, 01:51 PM   #2
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
I'm running a JX with a Eb Mods V2 head button shimmed for 20%, P4 Plug, 2060 pipe, 8mm stack, and i'm getting 11.30 at my local track in a 6T. my truck hauls!
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 08-03-2009, 01:54 PM   #3
rossoh10's Avatar
try running Torco fuel with changing anything ..I never got 9 minutes now with Torco I get 10+
TEAM WTF
RC10B5m
rossoh10 is offline   Reply With Quote
Old 08-03-2009, 01:55 PM   #4
wingracer's Avatar
Trader Rating: 23 (100%+)
Lower nitro will improve mileage and usually doesn't take away as much power as most of the other mileage tricks like smaller carb venturi, gearing, etc.
Another option, has anyone teched that guys tank
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 08-03-2009, 01:56 PM   #5
losiracer78's Avatar
im running a Mugen Ninja jx 21 and nitro juice 30% fuel and im getting right at 10 min
Screen Names Has Changed To mayhem04
losiracer78 is offline   Reply With Quote
Old 08-03-2009, 02:00 PM   #6
RBMike's Avatar
The 2 biggest things you can do is put in a smallish carb restrictor (ventury sp?) and run the right pipe. Picking the correct pipe makes a BIG difference in fuel milage. On my RB C6 I used the 2045 pipe & a 6.5mm restrictor & got over 10 minutes everywhere & even more on small tracks. With 10mm restictor & a 2020 pipe, 7 to 8 minutes on the same motor. I also found some fuels are bettter fro run time. Gen3 Byrons gave me a minute + more run time than gen2.
-EMBX6,T8 1400, RX8, 5S Lipo ,Elite-RC, RCM tray
-EMBX6,T8 1350, RX8, 5S Lipo ,Elite-RC, RCM tray
-B44 (Novak)
-ROAR 4 cell rule Blows
RBMike is offline   Reply With Quote
Old 08-03-2009, 02:01 PM   #7
Yeah and your probbaly one of those guys who drives like a pussy and still kicks everyones ass right?????? LOL J/K man............ Lets see. I have a JX-21, Have 8mm venturi, have EB Mods Button V1, will get a couple P4's and I have a 2060. Gonna get a gallon of 20%, lean the Beejesus out of it and try it tommorrow......Will report back......
Official NON-EXPERT
Old 08-03-2009, 02:02 PM   #8
jpalessi's Avatar
+1 i was out at 10 with 30%...but to get 10 min pits you need to get 11 or more... When i went to 20% i picked up about 90 seconds, and didn't loose much if any power... I did notice the throttle response wasn't as crisp but i think that actually helped my driving.. Lower Nitro content will also be a little harder to tune.
Joe Alessi
www.Lucky7RC.com
Old 08-03-2009, 02:04 PM   #9
jpalessi's Avatar
I drive STRAPPED! LOL and you can't run 20% with the V1 button..
Joe Alessi
www.Lucky7RC.com
Old 08-03-2009, 02:05 PM   #10
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
One of the biggest things you can do to help fuel mileage is not run the shit out of it down the straight. If you lift early or go to only 3/4 throttle it helps a ton with mileage.
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Old 08-03-2009, 02:08 PM   #11
yeah grabbing a hand full down the straight doesnt help much.
Old 08-03-2009, 11:49 PM   #12
Lille-bror's Avatar
This is a good thread
Run your engine on FAI fuel (0 nitro) and you will be surprised! +25% longer mileage compared to 25% nitro, less corrosion on the crank and bearings and a lot cheaper fuel costs!
Remove the head shims (measure the clearance between TDC and head: Min. 0.25 mm.) to increase the compression ratio.
A normal pro engine has a compression ratio around 8,5:1. To get the perfect ratio on FAI fuel, it should be 13,5:1. You will have to remove some material from the head. But start with only removing the head shims. I'm not sure, if you can get a turbo plug which is hot enough for FAI fuel. Try the Sirio #5.
I've run a well used RB WS7 II engine on FAI fuel, normal head, and 4 stroke plug with big success. I only removed the shims (clearance 0,3 mm). At a race NO ONE could tell the difference in my engine performance (acceleration and top speed) compared to all the others with 25 or 30 % nitro - except I did +10 min pr tank compared all others max 8 min.
I mix my own fuel. Use 16% synth oil. You will have to use more oil compared to "normal" car fuel due to the low fuel flow, when you engine can do so long mileage.
I'm surprised that RB's team drivers at Euro 2009 ran on 45% nitro... Nice to have sponsores
www.xray-shop.dk www.northtq.com
Best regards Bjarne Petersson, Denmark
XRAY / FX Racing Engines / OS Speed / HPI / Byron / HUDY / Proline / Sanwa MT4s / Sav÷x servos / Ultimate
I miss you Amy...
Lille-bror is offline   Reply With Quote
Old 08-04-2009, 12:29 AM   #13
i totally agreed on ron's post on the straight way just stay 3/4 throttle it really helps .............try to change the venturi 6.5 or 7.0 & it will improve ......but if still dont work that way lol....... last solution ........you got to limit your EPA throttle hope it helps
team terribles
mbx5rcr34 is offline   Reply With Quote
Old 08-04-2009, 01:31 AM   #14
Trader Rating: 21 (100%+)
+1 I set my epa so that the carb only about 80%, I've kind of a "lead finger" no matter what I'll press the throttle all the way on a straight so if the epa is set to 80% open then thats the max it opens.
I've tried 0% with 10% synth and 5% castor, first of all it is almost impossible to start the car even with the p4 plug and no shims and when it does start after the 100th attempt the idle is very erratic. I mix about 5 to 8% nitro and that really stabilizes (comparatively) the idle still the tuning window is pretty small and almost the same fuel mileage as 0%.
TopGearRC is offline   Reply With Quote
Old 08-04-2009, 02:02 AM   #15
Lille-bror's Avatar
P4? Is that a turbo plug?
You didn't have a hot enough plug. I'm 99% positive, that that will solve the issues (I have tried it myself on a normal plug engine). And ones the ignition is right, your engine will go +1 minutes longer, and have absolute no problem with start, idle etc etc
I miss you Amy...
Go-Tech Engines Thread MassiveMods Offroad Nitro Engine Forum 15106 06-26-2017 04:07 AM
Kyosho Gas powered 1/12th pan car ianhobbies Nitro On-Road 1083 02-24-2017 08:46 AM
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
fuel mileage help Miniracer23 Nitro Off-Road 34 04-19-2009 12:47 PM
Why i left R/C... long read... DaveW Chat Lounge 80 11-09-2007 12:28 PM
1/8th scale Fuel Mileage Thread Scootersisters Nitro Off-Road 8 10-07-2007 06:27 PM
