Old 08-03-2009, 09:24 AM   #1
Default steering servo return
I have a m11 and a hitec 7955 for steering.
ok. when i turn right or left it goes to my desired endpoint but when it returns to neutral it is slightly off from what straight is. I am pretty sure it wasn't doing this when i first got it. I have a mugen and my pillow balls and linkage are set correctly.
any one have any ideas?
with all the adjustments the m11 has there is not a steering return endpoints adjustment. you can only adjust the speed
any ideas?
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 08-03-2009, 09:28 AM   #2
when your testing this are you doing it on the ground or during driving,
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 08-03-2009, 09:31 AM   #3
on the ground. I will test it while moving later. It will align better when driving?
Mugen
Old 08-03-2009, 09:46 AM   #4
technically yes,
but Im surprised that with the 7955 and the amount of tourque - check or servo saver to make sure its not to soft - make sure nothing bent in the front end.....
Old 08-03-2009, 10:16 AM   #5
Integra's Avatar
test end point and stuff with the car propped off the ground and see what it does.
Old 08-03-2009, 10:20 AM   #6
losiracer78's Avatar
check your servo horn as well if its not alum it might be stripped a little and when you turn your servo is moven more then the horn and so when you strighten your wheels the are a little off
Screen Names Has Changed To mayhem04
losiracer78 is offline   Reply With Quote
Old 08-03-2009, 10:30 AM   #7
what_stanger?'s Avatar
Send a message via AIM to what_stanger?
it could be on your M11 steering wheel. I have heard some M11 radios having this problem of not centering.
check there, and if it is...do a search you'll find some info on how to fix it. Also you could send it in, from what I hear they fix it for free.
what_stanger? is offline   Reply With Quote
Old 08-03-2009, 10:37 AM   #8
Integra's Avatar
Interesting.
Old 08-03-2009, 12:09 PM   #9
if it's doing it while i am driving it's not enough to tell. Still does it though. even though it does not effect my driving per se, still agravating as hell. How much should my servo saver be tightened with the 7955? I did drop the trasmitter so i guess it could be the wheel. I don't want to be without it though while they fix it.
Mugen
Old 08-03-2009, 12:35 PM   #10
RJNicholson's Avatar
For a 7955 the saver needs to be pretty tight if its loose you will not get your full steering throw because it will break way to easy.. This happened to me and I thought I just didn't have enough off-power steering, and kept making setup changes. Then someone said I should check to make sure my saver is tight enough, and sure enough.. It was breaking under barely any pressure.
I know that isn't your issue, but just wanted to share that.
Also, if you think its your Transmitter here is the solution. Buy the M11x (provided your woman lets you ) then send in the M11 for repair, and when you get it back you have a great back up to the new bad ass M11x.
I know I would do that as its what I did with my spektrum equipment. Got a DX3R and I have a DX3S that came off a Losi RTR i bought for cheap and as a parts buggy. That way I at least have a decent back up instead of a DX2.0 or 3.0.
*Team Terribles*
Rigs Listed Below
Losi 8IGHT 2.0 B/BCE Chassis/OS VZB *Sleeper*/RE11/JRHV Servos/KHZ
Losi 8IGHT 2.0 B/Werks B7 Pro/2013/Hitech HV Servos
Losi 8IGHT 2.0 E/Mamba Monster ESC/Xcelorin 2100kv or NEU Castle 2650kv *RIP-LIPO FIRE
RJNicholson is offline   Reply With Quote
Schumacher Corner meche Electric On-Road 27727 07-20-2015 07:38 PM
Kyosho V-ONE RRR Evo boy2rc Nitro On-Road 3234 08-06-2014 11:43 PM
XRC 1/5 SCALE CARS brewer Australian Racing 3474 01-25-2011 03:10 AM
Monster / Stadium Trucks Offroad Thread fastwheels Indonesia Racing 1143 09-16-2009 02:04 AM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 01:50 PM
Steering Servo Choice Help idrum2loud Electric On-Road 20 01-30-2008 06:45 PM
Spektrum...is it good? Dredd Nitro On-Road 24 02-06-2007 04:36 PM
