Old 08-02-2009, 05:49 PM   #1
sperera's Avatar
Default Temp test over weekend.
Hello Everyone.
I managed to borrow a temp gun off a mate over the weekend to check the temp of the engine. So I went down to local park and run the buggy full throttle over grass, checked it several times. It stars between 70-80 degrees celcius, according to manual that came with buggy max temp is 132 degrees celcius so im well under that.
Its making good power and very consistent so im not going to try and push it any harder to get the temps higher, unless running it too cool can somehow hurt it? Any ideas?
Other than that im very happy with is so far, no major issues (except rear shockers leaking all their fluid).
sperera is offline   Reply With Quote
Old 08-02-2009, 05:57 PM   #2
IMO running an engine too cold can cause damage. If you don't get it hot enough, the sleeve cannot expand enough. This would definitely take life off you motor.
Shaun Davis
VP ProUSA
Mugen Seiki/Alpha Engines
Team Trinity
Miniracer23 is offline   Reply With Quote
Old 08-02-2009, 06:01 PM   #3
full throtle + grass + cold engine = bad
i think this has to be a joke. Rear shock towers leaking everywhere would be a issue in my book.
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 08-02-2009, 06:11 PM   #4
sperera's Avatar
Bummer, didnt know that. Do you think 80 degrees celcius is too cold?
I dont really want to change the tune because its seems happy and consistent, but more importantly I dont want to take life off my motor.
What I ment about rear shocks is that its an easy fix, even with my very limited knowledge.
Old 08-02-2009, 06:14 PM   #5
what kind of car? the shock thing isn't a big deal i guess. I don't know what 80 celsious is
Mugen
Old 08-02-2009, 06:45 PM   #6
sperera's Avatar
Model is BS802T (purcahsed from ebay new RTR kit). It has a .21 CXP (with the biggest heat sinks I have ever seen). 1/8 scale.
80 celcius is 176 F.
I tested the temp concentrating on area directly next to glow plug and the glow plug itself. Heat sinks were cooler than the area next to glow plug.
Old 08-02-2009, 07:36 PM   #7
i_like_f150s's Avatar
80C/176F is on the cool side, but it's not too cold. Does the engine seem to be running well with no sputtering, four-stroking, etc? Is it making good smoke? It's probably ok.
Checking temps by run WOT through the grass will not give you a clear indication of what the temps will be under race conditions, unless your racetrack is a grass-covered dragstrip.
i_like_f150s is offline   Reply With Quote
Old 08-02-2009, 07:41 PM   #8
sperera's Avatar
Idles beaut, no spluttering at all. Good smoke, none at idle but when accelerating yes nice stream.
Do you think the buggy will run hotter on gravel compared to grass? I thought grass would offer more resistance than gravel therefore it would get hotter.
Old 08-02-2009, 08:52 PM   #9
Integra's Avatar
Buggy + grass = no more clutch.....buggy's dont have the ground clearance to go very far in living grass.....sure if its beat down or 1/2 dead it wont be a problem but In general grass will be a significantly heavier load as apposed to gravel.
FYI Most if not all RC guys measure in Fahrenheit not Celcius.....and imo 170 is not hot enough.
Old 08-02-2009, 09:29 PM   #10
sperera's Avatar
The oval i take mine to has very short grass (under an inch) because footy is played on it every weekend but I didnt know that about the clutch. Thanks.
Bummer, I really didnt want to re-tune it to get it hotter but if im doing damage then I will.
Old 08-03-2009, 08:54 AM   #11
Integra's Avatar
1/2 turn on the highspeed is usually all you really need....just dont HAMMER on it for the whole tank.
Old 08-03-2009, 06:46 PM   #12
sperera's Avatar
Wow half a turn, isnt that allot?
I plan to buy a IR heat gun so I can always check the temp. Might go 1/4 and take it from there.
I havent really touched the LS needly, advised not to by local hobby shop, should I play with this as well?
Old 08-03-2009, 07:46 PM   #13
Integra's Avatar
Not until you have a firmer grasp on the whole tuning thing.
Old 08-03-2009, 07:59 PM   #14
sperera's Avatar
Understood, I will stay away from it for the time being!
Old 08-04-2009, 02:01 AM   #15
On-Board Temperature Gauge or hand IR gun is better?
sakis is offline   Reply With Quote
Tamiya Championship Series Neil Rabara Racing Forum 21158 Yesterday 01:41 PM
Tekin RX8 1/8 Scale Brushless ESC Thread sharkman Electric Off-Road 18828 08-07-2017 10:08 AM
lrp spx stock spec chuckharrisjr Electric On-Road 1131 02-22-2017 10:58 PM
calling all FUTABA 3PK users..... JayBee Radio and Electronics 1312 01-25-2015 07:57 AM
lrp brushless esc raceblast Electric On-Road 840 04-02-2012 04:45 PM
EP 1/10 Touring zafira2310 Indonesia Racing 10142 06-18-2010 11:09 PM
enough chit chat. compared, Mabuchi, 21.5, 19turn and 8.5 Bob-Stormer Electric On-Road 11 01-11-2008 01:53 AM
