Old 08-01-2009, 06:44 PM   #1
Default Fuel pressure lines
Hi, The topic was ment to be exhust presure lines, not fuel.
Does anyone know what the effects of having a longer of shorter exhust presure line has on the motors?
I know a shorter line will give you more presure inside the tank.
I am going to try and make an aluminium exhaust presure line to replace the normal fuel tubing in an attempt to get the exhaust gases inside the tank cooler.
Just not sure if you are better of with longer of shorter lines. ( More presure or less presure inside the tank)
If anyone knows anything about this it would be appreciated.
Thanks.
bucky1 is offline   Reply With Quote
Old 08-01-2009, 07:20 PM   #2
captain america's Avatar
Making a pressure line that's too short might lead to fuel sloshing back into the pressure line after you've filled the tank and cause your engine to run erratically; that's why you see the pros run at least 8 inches of pressure line.
The other thing that you might want to look into is that the more common use of silicone tubing seems to me to be a good thing, since unlike metal, silicone is a poor heat conductor, and will prevent the heat from the exhaust being transmitted up the line and to your fuel. There are some drivers now running aluminium heat sinks on the line to cool the exhaust flow, but I think that the heat sink's fins, added to the fact that it's sandwiched between two lengths of silicone tubing are what help in keeping the fuel cooler.
captain america is offline   Reply With Quote
V-ONE S Thread rhandee Nitro On-Road 4584 07-06-2014 06:19 PM
HPI R40 Nitro Car Forum EVOLUTION Nitro On-Road 11979 06-26-2012 07:57 PM
Need help with no fuel pressure problem pumpkinfish Nitro Off-Road 12 08-05-2007 09:44 AM
