Old 08-03-2009, 01:00 PM   #31
Trader Rating: 27 (100%+)
Originally Posted by Nikzilla View Post
I did not get what you just said....
you say it dies... is it just sitting there idling, or does it even after you start driving it around?
because nitro engines, if rich on the low end, will just load up and die while idling, so you have to what they call "clear it out" by giving it occasional blips of throttle to clear out the fuel that loaded up, so it doesn't die
you have to go easy, if its loaded up and you give it WOT then it will most likely just die
spawn_x is offline   Reply With Quote
Old 08-03-2009, 03:36 PM   #32
it dies the second I take out the igniter. Or when I run it with ingiter for a while. If I give gas, take out ingniter, then next time I give gas it cuts of again.
Nikzilla is offline   Reply With Quote
Old 08-03-2009, 04:18 PM   #33
K_B
K_B's Avatar
Trader Rating: 69 (100%+)
It sounds like it's just too rich either on the top or the bottom or both. It may be running so rich that it's fouling the plug. I would try a new plug and lean out the bottom about a half turn and see if it will at least idle a bit without the igniter connected. Do you have a hobby shop nearby? I would have them help you with it. You'll make alot more progress that way.
Getting tuning advice over the internet is like getting driving lessons from Stevie Wonder...
K_B is offline   Reply With Quote
Old 08-03-2009, 05:29 PM   #34
ok
Whos is stevie wonder?
Old 08-03-2009, 05:31 PM   #35
ok
Really?
AsSc8 is offline   Reply With Quote
Old 08-03-2009, 06:14 PM   #36
race raider's Avatar
Trader Rating: 38 (100%+)
ok
1 Corinthians 2:2 for I resolved to know nothing while I was with you except Jesus and him crucified.
race raider is offline   Reply With Quote
Old 08-03-2009, 07:30 PM   #37
Old 08-03-2009, 10:24 PM   #38
keavze's Avatar
what plug are you using now?
try a hotter plug. nova#5, sirio#5 or osp3.
yr tune is definitely out...seems too rich to me.
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 08-04-2009, 01:37 AM   #39
My plug is a copy of the stock and I tried running it with leanest setting possile for idle, half a turn lean away from stock for high, and 1 turn lean on low from stock.
Old 08-04-2009, 01:49 AM   #40
triplesix's Avatar
*ROFL*
Well said!
MBX6R
B5M Lowrider
DEX410
Supastox GT
triplesix is offline   Reply With Quote
Old 08-04-2009, 10:20 PM   #41
nuttynative's Avatar
A friend tore my ExTech down and found that the epoxy in the crank had melted/came loose and was blocking most of the ports. Cleaned it up and it runs fine.
nuttynative is offline   Reply With Quote
Old 08-05-2009, 01:22 AM   #42
triplesix's Avatar
I seriously doubt his engine has a filled crank since it's a bone stock Kyosho DBX.
MBX6R
B5M Lowrider
DEX410
Supastox GT
Old 08-05-2009, 02:50 AM   #43
dishsoap's Avatar
The exact and I mean exact same thing happend to me. I was about to throw it in the trash. I had some help from some friends and experienced drivers.
Mine runs like a champ now. Let me guess did you put after run oil in it?
HobbyTown USA Tucson!!! HobbyTown USA SRS!!!!
dishsoap is offline   Reply With Quote
Old 08-05-2009, 06:14 AM   #44
No on the after run oil. I went to the ExTech engines after running the OS Speeds. If you use after run oil in them it will eat the silicone out of the cranks so I just dont use it. My cars don't set very long without use.
