Old 08-02-2009, 07:46 PM   #16
jazjato's Avatar
How is the compression on the motor? Is there still pressure when rollng over by hand?
Team Terribles
jazjato is offline   Reply With Quote
Old 08-02-2009, 07:48 PM   #17
How am I supposed to tell that? Roll my hand over what?
Nikzilla is offline   Reply With Quote
Old 08-02-2009, 07:51 PM   #18
jazjato's Avatar
Roll the fly wheel with your finger where it sticks through the chassis. As the piston reaches the top of the sleeve you should feel pressure or a pinch before the piston comes back down.
This is done with out the ignitor or anything turned on.
Team Terribles
Old 08-02-2009, 08:52 PM   #19
ok, yes, just like before
Old 08-02-2009, 09:02 PM   #20
jazjato's Avatar
How was it before? Tight, small pinch, or no resitance?
If there is little to no resistance the motor may be shot.
Things I nromally look at:
Glow plug
air filter
Idle gap "if it is too far open it will throw all your other setting completly off"
needles
wet exhaust
smoke
compression
Clutch
Team Terribles
Old 08-02-2009, 09:14 PM   #21
it was the same, u needed alot of force to push it through the top.
The only thing on your list that I see, is that I have sometimes some fuel in liquid form fly out of the exhaust
Old 08-03-2009, 07:37 AM   #22
nbum[
Old 08-03-2009, 07:42 AM   #23
jazjato's Avatar
Nik,
without seeing it or hearing it am at a loss. If your saying everything is checking out it's gotta be a tuning issue. Not sure of your level as far as tuning. Most look at their needles like the face of a clock and only adjust a hour at a time. Ig you know your stock settings go there and start tuning slowly from there. You said you idle gap is ok. When you remove your air cleaner and look into the carb is should only be open a mm or so.
Team Terribles
Old 08-03-2009, 07:52 AM   #24
nuttynative's Avatar
I'm having the same issue with a Trinity ExTech .21. Will only run & rev with glow ignitor attached, take it off and it dies no matter where the rpm's are. I only have 1/2 gallon on it. I've tried four new plugs, checked the head bolts, back plate, new exhaust seals, replaced the entire fuel system, checked carb boot, carb pinch bolt, and air filter boot. I even opened a fresh gallon of fuel, same thing. When I took the engine out the chassis was clean as was the flywheel so I don't think the front bearing is bad. ? Any ideas?
nuttynative is offline   Reply With Quote
Old 08-03-2009, 11:13 AM   #25
yes, the Idle gap is perfect. and yes, I did take the filter off to check it. And I am kinda of completely confused. It makes a completely normal noise, the same noise as when it usially runs. The only difference there is that it just cuts off without the ingiter.
Old 08-03-2009, 11:20 AM   #26
Trader Rating: 27 (100%+)
I have this issue with my fairly new motor. Because its still tight, I run it very rich, so to get it to run on its own, I have to run it a bit with the ignitor on to get over 200 degrees, then it will idle without an ignitor..
If your mixture is super rich or super lean, it will not want to idle
also, I had this issue when the exhaust gasket from block to header was not the correct one.
spawn_x is offline   Reply With Quote
Old 08-03-2009, 11:29 AM   #27
change the plug
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 08-03-2009, 11:51 AM   #28
well my car is stock, and if you hold it with the ingniter in it still stalls after a while so I dont have enough time to get it to 200
Old 08-03-2009, 12:12 PM   #29
Do you give keep blipping the throttle? because it could be flooding
Old 08-03-2009, 12:21 PM   #30
I did not get what you just said....
