Old 10-03-2009, 08:10 AM   #46
I was briefly at the track yesterday and shot a couple of video sequences. Here are my needle settings:
HSN: approximately 2,75
LSN: approximately 4,25
I did richen LSN slightly to 4,5 - but the only result is it drops from high idle to low (and eventually really low) a lot faster.
Anyway, I hope someone might give me futher clues to why the initial idle is so high when watching these videos (I apologize it's kinda shaky - holding a 4PK + camera and hitting the throttle at the same time isn't my specialty ):
Video 1 and 2 (HSN: 2,75, LSN: 4,25):
youtube.com/watch?v=Ov8gYmO8Kgc
youtube.com/watch?v=r7XFYIcTkMA
Video 3 + 4 (HSN: 2,75, LSN: 4,5):
youtube.com/watch?v=fVrbwNJQpuw
youtube.com/watch?v=tNiNHSRiL9U
Note: bear in mind the increase in RPM on video 4 @ 00:07 is me increasing throttle to prevent the engine from stalling.
Any input welcome - thanks!
/Tom
tomkat is offline   Reply With Quote
Old 10-03-2009, 09:13 AM   #47
jrwoodchuck's Avatar
how much gap do you have at idle? just a guess, but i bet it's too much and you're having to keep it rich to keep the rpm down (and not working properly). i know it seems the oppisite, but check the idle gap.
Doug
TLR 22/M-11
“Looks like I picked the wrong week to quit sniffing glue.”
jrwoodchuck is offline   Reply With Quote
Old 10-03-2009, 05:21 PM   #48
aaron joy's Avatar
Trader Rating: 16 (94%+)
I also think the gap is not set right. In the videos you hear the idle drop twice, it shouldn't do that. It doesn't appear to be rich because it is not loading up when you accelerate. I would recommend following these links here and retuning your engine. Re-set your gap, tune your low-end and the top will follow.
http://www.rbproducts.com/mainEn.php...0.21%20engines
http://www.rbproducts.com/mainEn.php...e%20carburetor
Many think that RB engines are harder to tune then other engines, I don't find that to be the case. My tune stays pretty consistant week to week.
aaron joy is offline   Reply With Quote
Old 10-03-2009, 06:33 PM   #49
TIX
TIX's Avatar
Trader Rating: 17 (100%+)
change your plugs. i had the same problems and it angered me to no end.
i now run Sirio Buggy 7's or O'Donnell 99T's and its been problem solved
also give it more time and fuel. 2 of me 3 rb's tookup to 3-4 Gallons to start performing
Alan Nankervis.
TIX Race Designs. Plaig Bearings. Thunder Innovations
TIX is offline   Reply With Quote
Old 10-03-2009, 07:19 PM   #50
hyperc10's Avatar
Send a message via Yahoo to hyperc10
Use OD #77 plug seal everything up set your low end flush then lean one full turn. Run your high end at three turns out.If this thing doesn't run after doing this then throw your tank away get a new one and replace fuel lines.
hyperc10 is offline   Reply With Quote
Old 10-04-2009, 04:34 AM   #51
I run the 7mm venturi (orange) and in order to even see the idle gap I needed to pull out the venturi. I attempted to shoot som macro photos of the idle gap (proportionally bear in mind this is macro). To me (the untrained eye ) it seems to be in the area of roughly 0.5mm - 1mm.
See pictures here:
frcc.dk/pics/rb_b9
Thanks.
/Tom
Old 10-04-2009, 04:47 AM   #52
keavze's Avatar
idle gap of about 1mm is fine...0.5mm is slightly on the small side.
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 10-04-2009, 05:25 AM   #53
hyperc10's Avatar
After making these adjustments just set idle so it idles without dying or running away from you.Just try If I were you I would be trying anything right now.
Old 10-04-2009, 05:29 AM   #54
Lille-bror's Avatar
Check your complete exhaust system for leaks.
Cheers
www.xray-shop.dk www.northtq.com
Best regards Bjarne Petersson, Denmark
XRAY / FX Racing Engines / OS Speed / HPI / Byron / HUDY / Proline / Sanwa MT4s / Savöx servos / Ultimate
I miss you Amy...
Lille-bror is offline   Reply With Quote
Old 10-04-2009, 09:20 AM   #55
Kalgard Racing's Avatar
My needles are always within the previously noted settings. If you are having this much trouble I would:
1. Check the Rod, if it was broken in to rich for to long, it may be have to much wear. RB's like to be broken in hard, never easy and bloody rich.
2. Check for Clutch, Do not worry about what springs everyone else is running, I run two heavy and one medium springs so I can get the bottom set the way I like it and so the needles work the way I want.
3. Tank fuel lines, Clutch LOL
My B9 is running like a Raped Ape. Just like all my C6's...it is just an awesome motor.
OD 77T is my plug of choice.
Kalgard Racing is offline   Reply With Quote
