Old 08-02-2009, 09:21 PM   #46
captain america's Avatar
Originally Posted by jpalessi View Post
How is the speed modded and the ninja stock...
Please explain you theory behind this comment..
The OS SPEED is essentially a V-Spec that has a slightly reworked crankcase, a silicone filled, tungsten weighted & hardened crankshaft, and a ceramic rear bearing. To the best of my knowledge, the JX-21 has none of those things, so to me, the latter counts as a "stock" engine.
captain america is offline   Reply With Quote
Old 08-02-2009, 09:22 PM   #47
reggie l.'s Avatar
i second this...??????
_ClockWork-Racing_
http://www.clockworkracingengines.com/
~8t 2.0
~MUGGIFIED Lst-xxl
reggie l. is offline   Reply With Quote
Old 08-02-2009, 09:46 PM   #48
they are both stock since they are bought that way from the factory
or
If the speed is modded then so is just about every other turbo race engine.
but the fact is. if you want to argue this i guess the implied reference point would be the "stock" vspec in which case the ninja and speed both have filled and coated cranks whick would automaticly seperate them both from the "stock" vspec. BUT the ninja has 2 extra ports. The speed has a weight and ceramic bearing like countless other engines bought as "stock" so either all engines are either stock or moddified when they leave the store. But this just can't be.
A modded engine would be one that is "moddified" from it's original form.
it's late.
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 08-02-2009, 09:59 PM   #49
reggie l.'s Avatar
dude they have the same crank the speed just has the weights in it...the speed is a 3port-ninja is a 5..same cuts in the block its just the ninja has the .28 block...only thing different that you may be geting confused with "modded" is the ceramic rear bearing and weights in the crank...
_ClockWork-Racing_
~8t 2.0
~MUGGIFIED Lst-xxl
Old 08-02-2009, 10:10 PM   #50
reggie l.'s Avatar
ninja parts
http://www.amainhobbies.com/product_...ja-JX21-Conrod
http://www.amainhobbies.com/product_...-Piston-Sleeve
http://www.amainhobbies.com/product_...aft-DLC-Coated (i have the black crank like the speed just no weights...)
speed
http://www.amainhobbies.com/product_...g-Rod-Speed-21
http://www.amainhobbies.com/product_...iston-Speed-21
http://www.amainhobbies.com/product_...shaft-Speed-21
any one got better pics?
_ClockWork-Racing_
~8t 2.0
~MUGGIFIED Lst-xxl
Old 08-02-2009, 10:16 PM   #51
Hi reggie. I think my choice of terminology was inadequate, and I was certain that there were more differences between the two, but I went and called-up the Mugen website and there you go. Frankly, in light of this new info, and considering the striking price gap (on A-Main anyway) between the two, the SPEED seems like a bit of a ripoff. I still think that a modded (and by "modded" I mean sent to an independant contractor for machining) Ninja is the better choice, but that's just me.
Old 08-02-2009, 10:22 PM   #52
reggie l.'s Avatar
lol ok kool now...
_ClockWork-Racing_
~8t 2.0
~MUGGIFIED Lst-xxl
Old 08-02-2009, 11:36 PM   #53
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
Default The great debate ! LOL
I knew that would stir the pot! i have the blueprints of both engines stock and eb modded embedded in my brain. There is many differences between the two engines that most ppl don't realize because it can't be seen with the eye.. Crank weights (physical weight before slugging), crank bores, timing, case volume, ect ect.. Like dreaux said both engines are stock being that they are mass produced from the factory. i consider a "mod" to be something that was altered from it's original state.
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 08-03-2009, 01:24 AM   #54
yes pistons are the same,,,,sleeves and rods are different...
Ninja's P/L looks the same in design except OS's had a rework exhaust port.
Is that correct ?
Hengfook is offline   Reply With Quote
Old 08-03-2009, 05:33 AM   #55
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
Originally Posted by mugen8605 View Post
Are the pistons the same part between the OS and Ninja?
OK, it appears a lot of mis-infomation is floating around. The Ninja piston is not the same as the OS VSpec or Speed. The Speed and VSpec pistons are basically the same. Now, can you use a Ninja piston in a Speed or VSpec or vice versa-versa, yes. But you have to use the correct pin clips as they are different. One is C-Clip and the Ninja use a tabbed C-clip. Pop a regular c-clip into a Ninja piston and you'll have some fun tying to remove it later on for a rod change with no tab or piston notch to get at the clip. Also, the VSpec ports on the sleeve are configured differently from the Speed/Ninja, while the Ninja and Speed are practically indentical on the port shape and opening with the exception of the side ports, with the Ninja having a dual side porting instead of single.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 08-03-2009, 05:40 AM   #56
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Originally Posted by Frank L View Post
I agree the ninja is the budget speed engine. I dnt personally know anyone who would choose the ninja over the speed if money was not an issue. Very well said.
I would... for a truggy. The extra snap on the bottom makes the Ninja a better truggy engine. For a buggy, the smoothness of the Speed is better.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 08-03-2009, 08:16 AM   #57
jpalessi's Avatar
Yes, i forgot about the c clip difference... But i wouldn't say there is a lot of misinformation floating around.. Not from me anyway!
Joe Alessi
www.Lucky7RC.com
Old 08-03-2009, 01:48 PM   #58
Trader Rating: 32 (100%+)
my mag speed has crazy snap.
with OS p3 plug it's really strong bottom end
with Odonnel 97t plug it's crazy stuipd strong bottom end.
Z01B | Xerun 150A 2000kv | Hitec | Desire-power 6S LiPo
Z01T | Tekin RX8 1700kv | Hitec | Desire-power 6S LiPo
Support your LHS, Al's Hobby, Elmhurst
devilchrist is offline   Reply With Quote
Old 08-09-2009, 07:57 AM   #59
T-spoon's Avatar
Can anyone tell me the diffetence between the older and the newer ninja engine.Thanks...
Shane
T-spoon is offline   Reply With Quote
Old 08-09-2009, 08:12 AM   #60
i have the losi re11 for my vspec and works awsome. Was thinking it would work good in my ninja as well. Should i get the re10?? just to see how it works?
Mugen
