Old 07-31-2009, 02:41 PM   #1
Default BYRONS FUEL
I recently heard that Byrons is going back to their original formula(Hobby Shop Gold) and axing the Gen 2. Or keeping the name Gen 2 and using the original blend. Just wondering if true or not
moto431 is offline   Reply With Quote
Old 07-31-2009, 03:48 PM   #2
sickpuppy1's Avatar
Trader Rating: 25 (100%+)
NOT...
sickpuppy1 is offline   Reply With Quote
Old 07-31-2009, 04:29 PM   #3
Robert Walker's Avatar
Trader Rating: 74 (100%+)
Send a message via Yahoo to Robert Walker
My LHS ran out of the 30% Gen2 Race (11% lube) fuel and I tried the 30% Gen2 Pro (9% lube)fuel. The Pro fuel give me a little more performance but I wonder how hard it is on my engine.
I would be interested to hear which Byrons fuel everyone uses for racing?
Robert Walker is offline   Reply With Quote
Old 07-31-2009, 05:02 PM   #4
Quad Racer 34's Avatar
Trader Rating: 4 (83%+)
i just switched from O' Donnell 20% to Byrons gen2 20% 12% lubrication.. i love it. it runs better than the o donnell imo.
Dylan Gerard
Serpent - Desoto Racing - Picco - AKA - Hitec - RC Addictions Products - Tekin - VRP - Avid RC - SMC - MIP - SkipGear - The Ohio RC Factory
Quad Racer 34 is offline   Reply With Quote
Old 07-31-2009, 06:28 PM   #5
xlgraphicspro's Avatar
Actually any oil content over 9% isn't of any benefit to you cars engine. in the long run, your engine won't suffer the slightest bit.
TeamXray RCAmerica Hudy Xlgraphicspro Paint/ Impulse-Rc Clutch shoes.
Xray XB 808 O.S. Speed Or Ninja JX
xlgraphicspro is offline   Reply With Quote
Old 07-31-2009, 06:36 PM   #6
I've always ran Byrons...right now I'm running Gen 2 20%.The track I race at is tight and technical.A couple of buddies use 30% but don't really see any benefit to it....I'm just as fast on the 20%
Saber186 is offline   Reply With Quote
Old 07-31-2009, 06:40 PM   #7
actually the higher the nitro %age, the cooler your engine will run. Some engine Guru told me that, he looked pretty believable, so I took it as a fact.
Old 07-31-2009, 06:43 PM   #8
do u run the 9% lubricaton or the 12%>
Dylan Gerard
Old 08-01-2009, 01:22 AM   #9
SpeedFreak675's Avatar
our hobby shop that carried it around here stopped having it. so i'm mad cause i would have to order 4 gallons which would take me 4 years (or so) to get through. i loved that stuff. i've started using sidewinder 30% with 12% lube and i'm not totally sold on it yet.
SpeedFreak675 is offline   Reply With Quote
Old 08-01-2009, 06:44 AM   #10
Trader Rating: 61 (100%+)
byrons gen2 ....best fuel period ...i dont believe at the club level most of us race at ...that i personally need pro driver gen2 ...i would rather have the extra 2%oil ....i run byrons gen2 race 3000 ....30% ...never had a problem or issue that i could relate back to the fuel ..its as good as it gets ...the only other fuel ive considered running but have not run is sidewinder pro race ..i feel its as good as byrons ..alot of people locally run it and have good things to say ...
LATER COOKIE
TEAM REDS RACING ENGINES USA
TEAM PROLINE-RACING
TEAM RC AMERICA/XRAY/HUDY
zixxer is offline   Reply With Quote
Old 08-01-2009, 07:24 AM   #11
GMartinez's Avatar
Trader Rating: 85 (100%+)
I think your mistaken if you have an engine tuned for 20% & switch to 30% your engine will run hotter & you would have to richen it up this applies to glow plugs as well running a colder plug & then switching to a hotter plug will give you the same results & running less nitro will give you more runtime
more oil it runs cooler I run 20% GEN2 on 1/8th Onroad & 20% in Off-road & just a fast & faster than guys running 30% & if needed I go as high as 25%
I use the temp gun as a range & do not tune against the temp but tune on performance every engine is different
GMartinez is offline   Reply With Quote
Old 08-01-2009, 07:40 AM   #12
An idea. Find some peeps at the track that like it and all throw in for the case.
The Working Man is offline   Reply With Quote
Old 08-01-2009, 08:32 AM   #13
There seem to be a lot of people running 20% nitro. I never really tried it. I guess I will have to pick up a gal and give it a try.
I agree that Byrons is the best!
Old 08-02-2009, 12:48 PM   #14
most everybody at our track runs sidewinder, i've thought of that. maybe i can convert some over to the good stuff.
Old 08-02-2009, 01:06 PM   #15
wingracer's Avatar
Trader Rating: 23 (100%+)
Yes if you go from 20 to 30 without touching the needles and shims, it will run hotter because it is running too lean. Nitro carries oxygen with it, allowing more fuel to be burned, thus requiring a richer mixture. Also, nitro's lower octane rating will effectively advance the ignition timing, requiring a colder plug or lower compression (adding a shim). Once properly re-tuned and set-up, the increased amount of fuel and oil going through the motor will often result in lower temps. To see this effect requires ideal for performance tuning with both fuels in the same weather conditions of course, real world circumstances will not always match this theoretical condition.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Rc10ntc3 Taz_S Nitro On-Road 9437 05-28-2017 08:13 PM
Nitro On-Road Addict sa RC Manila Racers 12522 12-27-2015 05:51 PM
Which fuel do YOU use? XER987 Nitro On-Road 128 08-10-2007 08:20 PM
Morgan Sidewinder fuel??? V1-RRR-WC Nitro On-Road 9 07-05-2006 01:40 PM
FUEL Question timstmaxx Nitro On-Road 12 03-17-2006 09:29 PM
30% fuel motohead24 Electric Off-Road 14 02-08-2006 02:36 AM
brands of fuel??? corvettecrazy Electric Off-Road 14 07-27-2003 07:04 PM
