Old 07-31-2009, 12:33 PM   #1
snowboard094's Avatar
Default Any tips on starting my motor for the first time?
I have a mach 2 .21 buggy motor and it won't start for the first time. I have been threw three glow plugs and made sure not to flood the motor. It fires a little bit but not enough to start it up. I have been at it for three days now with no luck. I am very new to nitro so any tips would be appreciated.
thanks
-Electrical wiz-Let me check your shorts.....that came out wrong
"Team Terrible"
Ofna Hyper 10sc
T-maxx O.S .18tm
snowboard094 is offline   Reply With Quote
Old 07-31-2009, 12:38 PM   #2
lalmog91's Avatar
make sure you prime the engine, you dont want it spinning while its new with no fuel in it. also pre-heat the engine with a heat gun or a hair dryer to close to 200 degrees. this should make it start right up. finally make sure your ingiter and starter box or rotostart i guess is freshly charged.
lalmog91 is offline   Reply With Quote
Old 07-31-2009, 12:41 PM   #3
Make sure your glow driver is charged......
That one gets a lot of people.
McFly505 is offline   Reply With Quote
Old 07-31-2009, 01:03 PM   #4
I primed the motor. I blew threw the fuel line to get fuel to the carb. I didn't think i needed to do the hair dryer thing because is is 100 degrees down here. My igniter has a fresh battery in it. While pulling the pull start the rope came out of it so that will also set me back.
"Team Terrible"
Ofna Hyper 10sc
T-maxx O.S .18tm
Old 07-31-2009, 01:07 PM   #5
lalmog91's Avatar
im sorry to say but pull starts are doomed to fail, but even in 100 degree heat the engine is stubborn to start when brand new. so i would try heating it up even further.
if you can afford it go for a bump start set up. a starter box is pretty much a one time investment. i have been using the same box for about 5 years now and still going strong.
Old 07-31-2009, 01:12 PM   #6
Brad.R's Avatar
Trader Rating: 25 (100%+)
+1 on starter box. pullstart= starter box=
Bad Brad Rutland
Memphis Missle
Ricky Retardo, (Don't lose that number)
Oops my bad, you were in my line..
You just got passed.. IN THE AIR!!
Brad.R is offline   Reply With Quote
Old 07-31-2009, 01:20 PM   #7
i would go to a starter box if i could. My truck is a big block race slayer. The bb kit leans the motor at an angle to keep a fairly low cg making it so you can only use a pull/spin start.
"Team Terrible"
Ofna Hyper 10sc
T-maxx O.S .18tm
Old 07-31-2009, 01:45 PM   #8
Zerodefect's Avatar
Did you say your ignitor has a fresh battery IN IT? Its not one of those duracell type ignitors is it?
New engines need ignitors twice a strong as a run in engine. Make sure it can get that plug to glow white hot.
Other than that, take it to a local track, I'm sure someone can give you a hand.
Zerodefect is offline   Reply With Quote
Old 07-31-2009, 01:50 PM   #9
It is a dynamite glow starter with a d battery in it. It makes the plug glow orange/yellow.
"Team Terrible"
Ofna Hyper 10sc
T-maxx O.S .18tm
Old 07-31-2009, 02:07 PM   #10
sugelle's Avatar
Trader Rating: 62 (100%+)
Have you messed with the HSN or LSN (high Speed or low speed needles)? Also make sure your carb idle gap is set right (per your engine manual). If the carb is closed too much, you won't get enough air in to start and run the motor. It may help you to make sure everything is set to what ever the motors stock needle settings are.
Joe E
SMAC Trac/Dirtburners/Paint by:Snocamel Racing/VP Powermaster Fuel
MP9 TKI3:OS Speed/OS2090/KO RSx servos
ST RR Evo: Ninja BO2/OS 2060/KO RSx servos
sugelle is offline   Reply With Quote
Old 07-31-2009, 04:25 PM   #11
JUD
JUD's Avatar
If you went threw three glow plugs and it won't stay idled then you may have metal shavings in your motor.
JUD
Mugen Seiki - AB Mods - AIRTRONICS - Ninja - CR Graphics - Spektrum
JUD is offline   Reply With Quote
MINI Z beebop Indonesia Racing 7572 01-24-2017 09:16 AM
Xray T1FK05 Mdoc Electric On-Road 5433 01-31-2010 05:42 AM
Please Help Muah! Speedjunkyz Nitro On-Road 36 09-05-2008 07:13 AM
Engine Tuning 101 (General Tuning) Kemorc Onroad Nitro Engine Zone 41 11-19-2007 06:04 PM
Western Canadian TCS 2005 chrisman Canadian R/C Scene 629 08-30-2005 08:49 PM
Barracuda from Alex racing rcruv Electric On-Road 5110 02-27-2004 02:01 PM
