Old 07-31-2009, 12:14 PM   #1
Cory Kerber's Avatar
Default Idling Problem
I can't seem to get my buggy running right. I have to grab alot of throttle to keep it idling. The idle gap is pretty wide at that point, but it idles. As soon as i release the throttle it dies. It requires the idle gap to be open pretty far. Is that an overly lean bottom end? I had to lean the LSN alot just to get it to start and stay running. It runs fine when i give it alot of throttle, nice smoke, no bog. The you let go of the "trigger" and it stalls like it's cutting of the idle gap all the way. But it's not. The throttle linkage is set up perfectly.
Losi 8ight-Novarossi N21R-Hitec Servos-AKA-M11 Spektrum
*TEAM TERRIBLES*
Cory Kerber is offline   Reply With Quote
Old 07-31-2009, 12:19 PM   #2
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
what engine? how old?
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 07-31-2009, 12:26 PM   #3
It's a Novoarossi T421B it's pretty old, not sure exactly how old.
*TEAM TERRIBLES*
Old 07-31-2009, 12:31 PM   #4
Gary NJ's Avatar
You have a clutch shoe dragging or the low speed is too rich.
Gary - GMK Supply
www.gmksupply.com
Great products. Goofy names.
Gary NJ is offline   Reply With Quote
Old 07-31-2009, 12:32 PM   #5
jpalessi's Avatar
You should be able to set your idle gap at 1 turn from JUST closed and leave it... then if it doesn't idle, slowly lean the bottom end till it does...
Joe Alessi
www.Lucky7RC.com
Old 07-31-2009, 12:36 PM   #6
jpalessi's Avatar
good point Gary! could be your clutch!
Joe Alessi
www.Lucky7RC.com
Old 07-31-2009, 02:53 PM   #7
How would i be able to check the dragging clutch?
*TEAM TERRIBLES*
Old 07-31-2009, 02:57 PM   #8
pyromania's Avatar
Trader Rating: 18 (100%+)
Have you re-built the engine in the past?
If you did than you could have put the piston in the wrong way. The symptoms are that the engine will run but it wont stay idling.
Jesse Carrillo
Team Driver For:
TLR | Horizon Hobby | Nitrotane | Spektrum | HandleITHobbies | 818 Designs
pyromania is offline   Reply With Quote
Old 07-31-2009, 03:08 PM   #9
I just rebuilt the engine, but the piston is in correct, because in my motor it only works in one direction.
*TEAM TERRIBLES*
Old 07-31-2009, 03:13 PM   #10
pyromania's Avatar
You can put the piston in wrong but it will still run right, it just will not stay idling. Trust me I've done it.
Jesse Carrillo
Team Driver For:
Old 07-31-2009, 03:13 PM   #11
Maybe it would run right if i had a complete piston..
*TEAM TERRIBLES*
Old 07-31-2009, 03:17 PM   #12
pyromania's Avatar
Did you pull the back-plate while the piston was at BDC?
Jesse Carrillo
Team Driver For:
Old 07-31-2009, 03:18 PM   #13
I think i did when i rebuilt it. Because there isn't any debris in the motor. I just probably didn't even notice it being broken.
*TEAM TERRIBLES*
Old 07-31-2009, 04:45 PM   #14
Jaz240's Avatar
Trader Rating: 52 (100%+)
Ouch!....You have just learned 2 really good but expensive lessons..always move the piston to the top before you pull the backplate off, and always pay attention to which way the piston came out so you can put it back the same way...Sorry you learned the hard way. I promise you will never do that again!!!
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 07-31-2009, 04:59 PM   #15
gkn0315's Avatar
Trader Rating: 126 (100%+)
wow that sucks
Glenn Nail
STRC LCG Slash looking for electronics
1985 Associated RC 10 Novak t4 Trinity Monster Horsepower 27T futaba Jr
gkn0315 is offline   Reply With Quote
TEAM LOSI LST official thread stevenmichael Monster Trucks 1209 Yesterday 05:39 AM
Rc10ntc3 Taz_S Nitro On-Road 9437 05-28-2017 08:13 PM
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 05:09 AM
Tuning & Setting Guide... manteraperkasa Malaysian R/C Racers 122 04-20-2003 04:10 AM
Tuning problems with a 12TR anybody??? falcon68 Nitro On-Road 25 02-01-2003 08:32 PM
