Old 07-30-2009, 10:38 AM   #1
Garet Jax's Avatar
Trader Rating: 91 (100%+)
Default Engine Question
Hello all,
I have an engine that when I turn the crankshaft manually creates a metal on metal grinding sound. There is still pinch but it seems that when the piston is sliding up and down within the sleeve, there is too much friction.
I am comparing this sound to the other engines I have and there isn't as much grinding when doing the same thing.
Does it just need more oil or is something else likely wrong that could create problems if I were to run it?
Thoughts?
Thanks.
I am not a "Tech Master" nor even close. I simply have a lot of posts. If you want some sage advice, the only that I can give is don't listen to me.
Garet Jax is offline   Reply With Quote
Old 07-30-2009, 10:56 AM   #2
fatdaddy's Avatar
is the flywheel touching the crankcase?
HPI Racing - Hot Bodies - D8 Army!
**Team Terribles** (Answer RC, Fastlane Graphix, Caster racing, M2C Racing, and Dialed Inc!)
fatdaddy is offline   Reply With Quote
Old 07-30-2009, 10:59 AM   #3
chunk t's Avatar
As the piston slides through the pinch the bearings are getting loaded. I would give the bearings a serious look at. Pull the p&s and turn the crank over. Check for play & roughness.
chuck "chunk" thomas
1:10, 2-wd Stadium Trucks
B-Mod Tunnels
If ignorance is bliss... I must be in heaven!
chunk t is offline   Reply With Quote
Old 07-30-2009, 10:59 AM   #4
Garet Jax's Avatar
No flywheel or clutch components are installed. Other than the front bearing, the crankshaft is bare.
Old 07-30-2009, 10:59 AM   #5
Garet Jax's Avatar
p&s = piston and sleeve ?
Old 07-30-2009, 11:11 AM   #6
imaxx21's Avatar
Send a message via AIM to imaxx21
yeah, pop it apart and have a look inside
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 07-30-2009, 11:43 AM   #7
Trader Rating: 24 (100%+)
Garett,
If you don't have the equipment to go through the engine let me know. I offer a service that does engine rebuilds along with other things. I have a thread in this forum called "the Speed Shop". Check it out. I have bearings in stock, etc. We do a lot of engines, race preps, etc and have good references.
I would be glad to take a look at it for nothing, just get it to me. We can look at what it needs and go from there.
My email is alanburton20@gmail.com
Owner of the Speed Shop: A race prep shop for anything related to 1/10 and 1/8 off road racing. Check us out: https://www.facebook.com/pages/The-Speed-Shop/382214705269137?ref=bookmarks
ABURTON is offline   Reply With Quote
2009 Race Schedule - Sugarbowl Winner's Circle Georgia Racing 60 02-07-2009 03:40 AM
Lets go 3ports for 2006. MAVICXXX Malaysian R/C Racers 685 09-26-2008 10:47 AM
I need advise on pinch test/tunning... Mpowerz Nitro Off-Road 28 01-16-2008 12:36 PM
NEW FTGT2 with Novarossi TOP engine chilly4kc R/C Items: For Sale/Trade 77 02-11-2007 10:38 PM
Trinity G4 - Team Magic G4 E-Type puma1824 Nitro On-Road 3128 10-04-2005 04:17 AM
