help
i have an rc8 and when the motor is off and just the servos are on its fine but one i turn the motor on it glitches i took it of the stater box still the same when i shut of the motor its fine again could it be the battery or the receiver or somthin else
sounds like some metal to metal contact somewhere...possibly in the cutch, one of the bearings, even the motor itself....what kind of radio are you running? are you still running with crystals or 2.4ghz?
crystals well i used it yesterday without glitching for about 5 min then it just satrted doin it someone told me it might be the battery one of the wires mightbe bad
I think you are getting interference. get a 2.4 radio
Originally Posted by token
(Post 6138423)
i dont think its that cause if it was it would do that all the time wouldn't it
check all of your electrical connections, and double check that all your screws are tight. any metal to metal contact is gonna make it freak out.
have you tried another set of crystals? |
na dont have other ones im gonna try another reciever pack cause the one it had there was a tear near the battery
Originally Posted by tomtom1987
(Post 6138671)
just replace everything you can one piece at a time to try and find the culprit |
(Post 6138530)
well i did at the track and at my house and i live out in the country
