Old 07-29-2009, 04:55 PM   #1
freeman's Avatar
Default losi 454 .28 tuning
Has anyone been having issues with this motor or is mine just junk. Will not tune out. Brand new the front bearing was leaking fixed that and have sealed everything up still no luck.
freeman is offline   Reply With Quote
Old 07-29-2009, 05:21 PM   #2
Trader Rating: 24 (100%+)
The ones I have seen have ran great. Several were used at the nationals to get withing the top 40. These were bone stock. I have seen several through the speed shop either the 350's or 454's and the seem to do well. I actually have considered using them.
I'll be glad to check it out for you, just send it to me.
Owner of the Speed Shop: A race prep shop for anything related to 1/10 and 1/8 off road racing. Check us out: https://www.facebook.com/pages/The-Speed-Shop/382214705269137?ref=bookmarks
ABURTON is offline   Reply With Quote
Old 07-29-2009, 05:52 PM   #3
freeman's Avatar
Thanks alan, seem to have pretty close now but seems real sensitive to adjustments. BTW what kind of run time do they seem to be getting. It is 8port with 9.5 mm carb can't be good?
Old 07-29-2009, 06:57 PM   #4
sickmojave's Avatar
Mine tuned really easy and runs great with lots of power. but my run time is not good. 6 min moto and I will have to pit or run out of fuel. I'm looking for a .21 to go in it just to improve my run times.
dude I just seen where you are from. that is where I was born back in 63.
sickmojave is offline   Reply With Quote
Old 07-29-2009, 07:02 PM   #5
Brad.R's Avatar
Trader Rating: 25 (100%+)
i got that motor on my 8ight t 2.0 and i pit twice in a 20 minute main i know thats pushing it but the motor didnt get above 260f i had alot of carb issuses then i said he!! with it and i stuck a mach .26 carb on it and it runs awsome. there 30 bucks. you should consider picking one up. +s are brass fuel inlet. steel cable hook up. disadvantage, its only 8mm. but thats really all you need. that motor has sick power
Bad Brad Rutland
Memphis Missle
Ricky Retardo, (Don't lose that number)
Oops my bad, you were in my line..
You just got passed.. IN THE AIR!!
Brad.R is offline   Reply With Quote
Old 07-29-2009, 08:49 PM   #6
8&stuff's Avatar
Trader Rating: 55 (100%+)
wish i had one that had probs to send to burton
Mark Buecker
8&stuff is offline   Reply With Quote
Old 07-30-2009, 09:08 AM   #7
The one I speak of from the nationals ran 230 degrees, had a stock carb and with a truggy he got real good runtime. We never had to press the issue because of 5 minute quals but he ran 5 mniutes and had a lot left.
One thing to remember and I talked to The Drake about this....
With the stock pipe that comes with the rtr's it will run hot and just be a fair running engine. POwer, runtime, temp will all suffer.
Try runnnig the losi re11 pipe. Better power, runtime and temps will drop.
http://www.losi.com/Search/Default.aspx?SearchTerm=re11
www.carolinasrc.com has a 15% discount.
Old 07-30-2009, 01:59 PM   #8
freeman's Avatar
Thanks for all the replies, My thoughts exactly about pipe and carb cause the motor does have amazing power. Does anyone what other carb will fit I beleive the barrel is 12mm?
Old 07-30-2009, 02:48 PM   #9
DiaRh34's Avatar
Send a message via AIM to DiaRh34
Probably the one bigblock mentioned
Taco
Bullet Town raceway Milan, Tn
TLR 8b - Tekin - SMC
DiaRh34 is offline   Reply With Quote
Old 07-30-2009, 09:26 PM   #10
Brad.R's Avatar
yea, diarh34 was my pit man for that race. its going to be the best carb for the money
Bad Brad Rutland
Memphis Missle
Old 07-31-2009, 03:23 AM   #11
SpeedFreak675's Avatar
I had been having some issues with my losi 350, but i seem to be getting a handle on it. they are very touchy when it comes to tuning, a little goes a long way. mileage doesn't seem to be great, but i still have the stock pipe on it.
my main issue is that it isn't restarting when it flames out or runs out of fuel. i thought i might have gotten it figures out today but my receiver pack dumped after my last adjustment, so i'm not sure. i think my botom end was amazingly fat and loading up the case with fuel when it died.
it does have great power though.
SpeedFreak675 is offline   Reply With Quote
Old 07-31-2009, 05:41 AM   #12
Brad.R's Avatar
when i pitted for diarh34 he flamed out twice and it took me at least 45 seconds to restart him.
Bad Brad Rutland
Memphis Missle
Old 07-31-2009, 12:37 PM   #13
it does seem to have to sit before it comes back to life. but then when my does, its all kinds of loaded up and i have to get it cleaned out before it will stay running again.
has anyone tried any other pipes. i was thinking of getting the losi re11 but was wondering how well other pipes worked. maybe a jp-3 or dynamite 086.
Old 07-31-2009, 01:08 PM   #14
Brad.R's Avatar
i have heard good things about the jp-3. also the jp-2. i think the -2 has more top end.
Bad Brad Rutland
Memphis Missle
Old 07-31-2009, 01:40 PM   #15
coviello's Avatar
the 2 has more bottom end. the 3 is a bottom-mid pipe,the 4 is a mid to top and the 6 is just a top end pipe
coviello is offline   Reply With Quote
The Speed Shop(Birmingham, Alabama) ABURTON Nitro Off-Road 3208 08-25-2015 12:33 PM
Who makes the Losi RTR 350 engine? Cannondale1974 Offroad Nitro Engine Forum 197 04-04-2011 05:51 PM
