Old 07-29-2009, 04:55 PM   #1
sperera's Avatar
Default Strange problem
Ok so I was out at the local park last night having some fun bashing around a gravel track. Was going awesome, love drifting it sideways around 90 degree corners. got through half a tank or a bit more and nothing, no drive. Engine still running and responding, can rev it but wouldnt move.
So I turned it off and took it home, put it on bench, took cover off. Noticed a rock stuck in heat sinks on engine where glow plug is, its was jammed in there pretty good. Got it out with screw driver without damaging anything. Started it up again and running fine, responding to everything.
I cant work out how a rock in the heat sinks could prevent all drive???
Model is BS802T 1:8 .21 CXP
sperera is offline   Reply With Quote
Old 07-29-2009, 05:03 PM   #2
Frozenshades's Avatar
Sounds like the problems are unrelated. I've never heard of a rock in the cooling head causing a problem in the clutch/drive train.
Frozenshades is offline   Reply With Quote
Old 07-29-2009, 05:05 PM   #3
gravel = bad for my buggy. But anyways. It was not the rock stuck in your heat sink. THEre was one in the wheel hub or flywheel hole (but that would make it stop). anyway it wasn't the one in the cooling head. Wheel hub man.
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 07-29-2009, 05:06 PM   #4
hustler777's Avatar
Send a message via MSN to hustler777 Send a message via Yahoo to hustler777
well you probly had a rock in the spur gear and it fell out before you got home....if it wasn't that then the rock in the head had some sort of mystical power that prevented anything around it to rotate....you should have kept it and took to your next race...it could be R/C Kriptonite LMAO!!!!!
Sometimes you gotta go back to come back...
hustler777 is offline   Reply With Quote
Old 07-29-2009, 05:06 PM   #5
Fabulous's Avatar
Trader Rating: 42 (100%+)
Sounds like you might have had a stone stuck between the center gear and chassie. Once you shut it off the stone fell out.
22 4.0 - Mod
22 3.5 - Stock
22-4 2.0 - 13.5
8ight E 4.0
Fabulous is offline   Reply With Quote
Old 07-29-2009, 06:39 PM   #6
sperera's Avatar
Awesome, just what I thought, couldnt work out myself how something in the heat sink could have caused that. Oh well all working now thats all that matters.
Old 07-30-2009, 05:56 AM   #7
NITRORULES's Avatar
Thumbs up
+1
IF YOU CAN'T TUNE IT, IT'S JUNK!
NITRORULES is offline   Reply With Quote
Old 07-30-2009, 04:07 PM   #8
sperera's Avatar
Started it and ran it in garage last night, all seems to be fine. Most likeley the rock in centre gear.
Could it be the clutch with intermittent problem? I hope not ive only run 1.5 litres through it.
Old 07-30-2009, 04:21 PM   #9
fatdaddy's Avatar
its worth a check, but highly unlikely.
HPI Racing - Hot Bodies - D8 Army!
**Team Terribles** (Answer RC, Fastlane Graphix, Caster racing, M2C Racing, and Dialed Inc!)
fatdaddy is offline   Reply With Quote
MEGA (by Picco) thread ttso Onroad Nitro Engine Zone 1318 09-13-2010 04:56 PM
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 01:47 PM
Futaba 2.4GHz radio_car_racer Electric On-Road 360 01-31-2008 03:37 AM
Rossi LS1 .21 onroad mrx Onroad Nitro Engine Zone 17 06-10-2006 09:49 AM
Problem with starting engine - Pull start Aceboy Electric Off-Road 17 05-02-2006 03:52 AM
Strange radio gear problem (throttle and brake only) peanutbrains Nitro On-Road 6 04-06-2006 03:35 AM
Strange problem alucard13 Nitro On-Road 41 04-18-2003 02:30 PM
