Old 07-29-2009, 09:59 AM   #1
zonda's Avatar
Default piston and sleeve assembly
just tore down my mach 28 for an inspection. The engine has seen a few gallons so its no dout lost compression and the piston is stained with a bronze and brown colour. when attempting to remove the sleeve I found it really difficult. Trying to put the sleeve and piston back in is almost inposible. Is this normal ? Was wondering if the sleeve has been damged or even the block itself.
Any feedback or comments would be great, Thanks
zonda is offline   Reply With Quote
Old 07-29-2009, 10:36 AM   #2
Madbrad's Avatar
Trader Rating: 29 (100%+)
Did you get the small pin on the block and sleeve lined up ?
XT8 - Werks B5
Hyper 10SC Novak PRO ESC 4.5HV
Madbrad is offline   Reply With Quote
Old 07-29-2009, 10:50 AM   #3
Cory Kerber's Avatar
Try putting some after run oil around the sleeve, then sliding it in. Also like Brad said, make sure the notch in the sleeve is lined up with the notch in the case.
Losi 8ight-Novarossi N21R-Hitec Servos-AKA-M11 Spektrum
*TEAM TERRIBLES*
Cory Kerber is offline   Reply With Quote
Old 07-29-2009, 11:23 AM   #4
zonda's Avatar
cheers guys tried both your methods and found it much easier, thanks
Go-Tech Engines Thread MassiveMods Offroad Nitro Engine Forum 15106 06-26-2017 04:07 AM
Engine tear down SirKarnage Nitro Off-Road 21 12-01-2008 08:23 PM
