Old 07-28-2009, 07:07 PM   #1
dadsvtechonda's Avatar
Default how do i switch fuels
Proud Supporter Of WWW.READYROLLERS.COM
(thanks for all the support rome couldn't do It without you)
Losi 8ight T 2.0 Alpha S852 (Orange Head)
www.hobbyhut.com
dadsvtechonda is offline   Reply With Quote
Old 07-28-2009, 07:10 PM   #2
wingracer's Avatar
Trader Rating: 23 (100%+)
Step 1. Remove fuel from tank.
Step 2. Refill tank with different fuel.
Seriously, just swap it out, richen the top half a turn, put it on the track and re-tune.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 07-28-2009, 07:10 PM   #3
xlgraphicspro's Avatar
just switch and re-tune! if your bumping the nitro%age, you might have to add a head shim if your going up 20% to 30%, or take one out if your going down 30% to 20%.
TeamXray RCAmerica Hudy Xlgraphicspro Paint/ Impulse-Rc Clutch shoes.
Xray XB 808 O.S. Speed Or Ninja JX
xlgraphicspro is offline   Reply With Quote
Old 07-28-2009, 07:16 PM   #4
i am im going from trinity 20% to byrons 30% how would i know if i have to add a head shim
www.hobbyhut.com
Old 07-28-2009, 07:20 PM   #5
looper's Avatar
Trader Rating: 19 (100%+)
Send a message via Yahoo to looper
if you didnt remove any headshims to run 20% then you are already set and ready to go.
Looped Designs Paintwerks
http://ldpaint.webs.com/ Email: Looped.designs@gmail.com
looper is offline   Reply With Quote
Old 07-28-2009, 07:21 PM   #6
what engine do you run? I have a O.S.v-spec speed, and regular version. I have 1 head shim and I also use byrons 30%
take your cooling head off and check for copper rings. if it's a turbo plug engine the shim is under your head button.
Old 07-28-2009, 07:28 PM   #7
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
Your speed and your stock v spec, come with 2 shims. 1 copper and 1 aluminum..
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 07-28-2009, 07:33 PM   #8
i have a rb c6
www.hobbyhut.com
Old 07-28-2009, 07:41 PM   #9
sorry, I meant to say that. the aluminum one stays at all times, the copper one stays for 30% of you can chuck it for 20%
Old 07-28-2009, 08:08 PM   #10
DiaRh34's Avatar
Send a message via AIM to DiaRh34
I took a shim out to go from trinity 20% to sidewinder 30% on my 2.0 rtr
Taco
Bullet Town raceway Milan, Tn
TLR 8b - Tekin - SMC
DiaRh34 is offline   Reply With Quote
Old 07-28-2009, 08:59 PM   #11
Frank L's Avatar
Trader Rating: 148 (100%+)
+1 Thats what I'm talking about.
Old 07-28-2009, 09:37 PM   #12
jpalessi's Avatar
Originally Posted by dadsvtechonda View Post
i have a rb c6
C6 comes ready to go for 30%.
Joe Alessi
www.Lucky7RC.com
Old 07-29-2009, 07:29 AM   #13
megasaxon's Avatar
Trader Rating: 25 (88%+)
Send a message via AIM to megasaxon Send a message via Yahoo to megasaxon
shouldn't have done that
Team Associated RC10GT
Team Associated RC10GT2
megasaxon is offline   Reply With Quote
Old 07-29-2009, 07:33 AM   #14
No you shouldnt
When changing fuel , just let it idle for a half tank, to let the oils from the new fuel clean out the old.
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 07-29-2009, 02:37 PM   #15
I wouldn't mess with the head shims till you run it. Usually, If you need a shim you can hear the engine pre-detonating. It's hard to explain the sound. Almost like a sizzling sound. How many head shims you run has a lot to do with what climate you're running in. It's possible you were running too many already, and switching fuels will put you right where you need to be. Just make sure you don't start to see pitting on the top of the piston, thats a sign of pre-detonation.
Miniracer23 is offline   Reply With Quote
Please Help Muah! Speedjunkyz Nitro On-Road 36 09-05-2008 07:13 AM
Which fuel do YOU use? XER987 Nitro On-Road 128 08-10-2007 08:20 PM
Fantom Engine Manual = ABC Engine Bible Horatio Monster Trucks 9 02-05-2007 07:35 AM
30% fuel motohead24 Electric Off-Road 14 02-08-2006 02:36 AM
