Old 07-26-2009, 07:41 PM   #1
Default i keep breaking turnbuckles?
i keep breaking turnbuckles on rear of nitro rustler!
is there a different kind of turnbuckle i can put on it instead of the ball cups? is there a straight screw and nut type? thanks if you got a site with for sale let me know thanks again.
wade.217 is offline   Reply With Quote
Old 07-26-2009, 07:50 PM   #2
JPierson's Avatar
Cool
RPM....search them!
HB D8 & D8t GRP .21 & O'DONNELL SS.21
JR 8711 & 9100s & Hitec 7955TG
M11 2.4 FHSS-2 •TEAM*TERRIBLES•
"I know I can't drive!! You still ACT like you can!!"
JPierson is offline   Reply With Quote
Old 07-26-2009, 08:42 PM   #3
Default thanks jp!
thanks
Old 07-26-2009, 09:30 PM   #4
quick question, what kinda vehicle are you running,
also you said ball cups. so I'm assuming 1/10 scale. what are you doing when they pop off.
I used to run a RC10GT, and it would occasionally pop a ball end. a couple hard hits to the wall stressed the rod end and loosened it too much, replaced stock ones with RPM's, problem solved . The down fall with the captured style if your popping the ball cups from impacts instead of just popping the rod end, you end up breaking parts like knuckles or bending the tie rods. so then problem fixer just became bigger problem maker.
Good Luck At the Races. Scott
rc_racer1 is offline   Reply With Quote
Old 07-26-2009, 09:36 PM   #5
I just re read your post, rear tie rod ends, check your suspension make sure there isnt any binds, and double check that the rod ends are lined up straight and not fighting each other. I sheared a rod end on my D8 because the ends weren't lined up and it was flexing the outer end side to side when the suspension was cycling through the rough stuff.
good luck getting it fixed.
Scott
Old 07-27-2009, 11:36 AM   #6
Default thanks
scott, thanks for the help looking into all those tonight at the track when i run through the sand whoops tonight ill pull off during practice right after and look at them !
thanks again.
Hpi Pro 4 Barry White Electric On-Road 16052 08-08-2017 02:05 PM
Tamiya TA05 Touring Sedan kentech Electric On-Road 11403 06-21-2017 03:10 AM
RCLAB 7even Cars. chrisman Electric On-Road 1443 03-21-2017 11:55 AM
kyosho electric offroad b-man777 Electric Off-Road 9014 12-22-2012 07:36 AM
Team Losi XXX-T CR, What are yours opinions ? Jason Pelletier Electric Off-Road 2231 01-19-2012 09:16 PM
Awesome used RC10GT for trade......sale? WYLDTHING R/C Items: For Sale/Trade 30 05-16-2006 03:32 PM
