Old 07-28-2009, 02:14 PM   #16
bgbelden's Avatar
Originally Posted by houston View Post
thats a terrible situation with your engine , hope i can help .
use an inline fuel filter (even on your losi) , 8" of pressure return line , 7mm carb restrictor , odonnell #77 , sounds like you are really rich on the low speed and have just been leaning the high speed out since you broke the engine in ? , reset the carb , pull the slide barrel out screw the low needle in all the way and back out 3.75 turns , set the idle at about 1mm open or just a little less , hsn just in from flush with the brass housing .
i didn't notice what pipe you are running but it will run (terrible) with any pipe , just runs better with certain ones (ofna 063)
hope this helps ,
monty
oh , and use 30% or pull the shims on the underhead down to .60mm
6.5 currently
JP3
I went with 20% only for longer engine life, is this not the case? And i have no idea about shims, just whatever came with it.
I will put extra fuel line and switch plugs and restrictor, pipe will stay the same due to cash (got none)and fuel i'll see about switching.
''Life's tough ........
it's even tougher if you're stupid..''
-- John Wayne
bgbelden is offline   Reply With Quote
Old 07-29-2009, 09:13 PM   #17
bgbelden's Avatar
Originally Posted by topcat-lll View Post
I Have four Novarossi engines, love their engines but hate the plugs. McCoy 8
or an Odonnell #77 or #100 the #99 is too cold for 20% fuel trust me.
Bought 2 #77's so we'll see this weekend.
-- John Wayne
Old 07-30-2009, 01:23 AM   #18
dlb
Also check the fuel tubing that it is not sucking air in when the tank lid is open.
dlb is offline   Reply With Quote
Old 07-30-2009, 07:39 AM   #19
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 07-30-2009, 07:55 AM   #20
Buy a Mc8 and compare the two.
topcat-lll is offline   Reply With Quote
Old 07-30-2009, 07:58 AM   #21
Too cold
Old 07-30-2009, 08:28 AM   #22
Glorykid's Avatar
sounds like a similar problem happening over here, with the exhaust so close, spilling cold fuel onto the hot exhaust will cause these problems.
Make your self a divider between your tank and exhaust, this is bolted to the shell.
Nemo Racing~Agama~Bullitt~Beta~Piranha~Racer
Glorykid is offline   Reply With Quote
Old 07-30-2009, 04:26 PM   #23
houston's Avatar
Trader Rating: 91 (100%+)
great standard plugs
odo77
odo100
mccoy mc8
the newer special ultra c5g (silver body)
turbo
odo77t
odo97t
novarossi special ultra c5tgc (silver body)
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 07-30-2009, 05:37 PM   #24
bgbelden's Avatar
Saturday is almost here so i will let everyone know the outcome after i do the pressure line/filter technique and use O'donnell 77 plugs. I also added a quart of 30% to my half gallon of 20% thereby making it around 23%
-- John Wayne
Old 07-30-2009, 05:55 PM   #25
houston's Avatar
23% huh
interesting
Old 07-31-2009, 03:34 AM   #26
air8's Avatar
LOL. Too much science here for me.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 08-02-2009, 09:11 AM   #27
bgbelden's Avatar
Well aside from the rain cutting the main to 8 minutes i had no problems all day used the O'donnell #77 plug.
-- John Wayne
Old 08-02-2009, 11:22 PM   #28
houston's Avatar
sooooo..................... what did you notice after the plug change ?
Old 08-02-2009, 11:30 PM   #29
bgbelden's Avatar
Nothing really performance wise just that it stayed running when i came in the pits and at the start of the race. Probably the plug #77 but also could have been the dynamite 086 pipe. I was very happy but rain sucks on race day.
Thanks for everyones help.
-- John Wayne
Old 08-09-2009, 09:20 PM   #30
sangyi41's Avatar
Trader Rating: 16 (94%+)
now i have a problem here..
i running 0.70 shim op.25% Tornado Nitro.Os A5 Plug I Run In malaysia.
The Engine Give me feeling like very under power.it performance just like normal 3 port engine.i already break in this enigne very well with heat cycle 13 tank temp around 200f.
the engine no toq and top end also..itzzit tuning problem?
Tough Racing Belt For MALAYSIA.TEAM POWER RC PRODUCT MALAYSIA Sale And Support.
FACEBOOK ONLINE RC STORE>>http://www.facebook.com/#!/groups/227796347309837/
Call/Sms/Whatsaps +60175007932 Location(Taiping,Perak)
sangyi41 is offline   Reply With Quote
Novarossi engines thread EVOLUTION Onroad Nitro Engine Zone 5360 08-14-2017 11:48 PM
New Novarossi .21 offroad Plus 4 dsl Offroad Nitro Engine Forum 3759 09-01-2014 05:30 PM
Novarossi Plus 21 7bt Help prphze Nitro Off-Road 25 12-23-2007 06:52 AM
NOVAROSSI PRODUCTS teamcobraracing Australian Racing 158 12-09-2007 11:52 PM
