Old 07-26-2009, 06:20 PM   #1
tallyram's Avatar
Default ninja(mario rossi) crank pin size?
i need to know what the "acceptable" measurement is on the mr ninja's crank pin.
tallyram is offline   Reply With Quote
Old 07-26-2009, 08:07 PM   #2
22Racer's Avatar
Trader Rating: 67 (100%+)
They should be around .1965 or so, I would consider it junk if it's under .194 or less. They are one of the best wearing cranks I've worked on.
Rex
Rw modding and engine repair http://www.rw-mods.com
Sleeve resizing $15.00/ motor rebuild $30.00
Argus engine distributor/Avid bearings/ Alpha engines/
Fx Royal engines/ Maxy Engines
e-mail rwmods@yahoo.com Rex Welch
22Racer is offline   Reply With Quote
Old 07-26-2009, 08:18 PM   #3
tallyram's Avatar
hey, i really appreciate the help! this one is from .1965-.1970, so i guess i'm good to go. it has about 5.5 gallons on it and all is original except for tko bearings. gonna freshen her up with a new p/s, rod, wrist pin, and clips! these are some extremely reliable engines! once you figure out how to tune them you can have fun racing and not worrying about messing with them.
Old 07-26-2009, 09:21 PM   #4
22Racer's Avatar
Dont' waste your money on a new piston and sleeve. I can pinch it for you, you will probably get another 5 gallons on it for only $15.00 and not have to waste time breaking it in.
Rex
Old 07-27-2009, 04:43 AM   #5
plus2ss's Avatar
Good luck finding a conrod for a mr21. ive been looking and it seems to be out of stock everywhere. If you do find a company that has them in stock, let me know.
plus2ss is offline   Reply With Quote
Old 07-27-2009, 05:58 AM   #6
http://metrolinalxa.com/carolinasrc/...idproduct=2182
I order on a couple weeks ago, they have them in stock
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 07-27-2009, 03:00 PM   #7
tallyram's Avatar
a couple of summers ago i bought both .21s and parts to rebuild them. i have all the parts that i need minus a new carb.
Old 07-29-2009, 08:41 AM   #8
plus2ss's Avatar
Does anyone know if the mr21 rod works in the GRP .21?
Old 07-29-2009, 08:58 AM   #9
no it does not
Old 07-29-2009, 10:27 AM   #10
Timmo's Avatar
Trader Rating: 15 (100%+)
Aren't they both GRP based engines.
Timmo is offline   Reply With Quote
Old 07-29-2009, 01:14 PM   #11
Yes they are but they are not the same engine cut from the same shell. Look at all the manufactors and how many engines they make with different parts.
Old 07-29-2009, 02:06 PM   #12
22Racer's Avatar
I thought a friend of ours put Grp rods in his Grp Ninja's but I personally haven't.
Rex
Old 07-29-2009, 09:50 PM   #13
Timmo's Avatar
Can someone verify this.
Old 07-30-2009, 05:49 AM   #14
plus2ss's Avatar
Im not 100 percent sure, but a couple of people have said all GRP engines internals are interchangable. I called carolinasrc and they dont have the mr21 rod in stock. It would be worth the try if i could find one.
Old 07-30-2009, 07:31 AM   #15
No they will not - the GRP ROD is about 2mm shorter than the MR rod - I just pulled the rod out of bother engines and compared - they are two different rods
