Old 07-25-2009, 01:06 PM   #1
davidg01234's Avatar
Default Running rc in 100 degree weather
is it ok to run a nitro rc in 100 degree weather as long as the temps stay good?
What is an average running temp for a 8 scale buggy, to be exact a Force.28
Also to run in this kind of weather could you just richen it some and check the temp every now and then?
davidg01234 is offline   Reply With Quote
Old 07-25-2009, 01:12 PM   #2
rc-mike's Avatar
In theory you actually would have to lean it out a little to keep the same tune but just tune it like you normally would. If you aren't comfortable tuning by sound/smoke/etc. then I would be sure to check the temps.
rc-mike is offline   Reply With Quote
Old 07-25-2009, 01:21 PM   #3
thanks, what is the average running temp
Old 07-25-2009, 01:24 PM   #4
Trader Rating: 21 (100%+)
Have a little experience running at temps over 100F. If youre running 250F at 80F, expect to run 270F at 100F unless you do something about it. I use a bigger coolong head since I run this way most of the summer and I try to stay a touch rich. Engines are trx 2.5s and 3.3s and they tend to run hot anyway. Bigger cooling head helps that. Otherwise they would be too hot. I run mostly on the grass too which doesn't tend to help temps either.
Duster_360 is offline   Reply With Quote
Old 07-25-2009, 02:15 PM   #5
Trader Rating: 61 (100%+)
colder glow plug
LATER COOKIE
TEAM REDS RACING ENGINES USA
TEAM PROLINE-RACING
TEAM RC AMERICA/XRAY/HUDY
zixxer is offline   Reply With Quote
Old 07-25-2009, 02:45 PM   #6
Originally Posted by zixxer View Post
colder glow plug
what about a mcCoy
Old 07-26-2009, 07:05 PM   #7
crotty777's Avatar
I live in nevada and run all summer long outside temps can get to 120 there is nothing wrong with running the engine 270-280-290 as long as the tune is right. the temp of the engine dosent mean anything as long as u have it tuned right.
*Dialed RC Hobbies, Windwater RC, Kustom Kolors, HRP, Sweep Racing,
RC Concept*
crotty777 is offline   Reply With Quote
Old 07-26-2009, 09:11 PM   #8
omarwashington's Avatar
I've also hear that when the weather is hot to lean it out, I still dont understand that concept but I guess its correct.
RCCARS!
omarwashington is offline   Reply With Quote
Old 07-26-2009, 09:23 PM   #9
unsp0ken's Avatar
Trader Rating: 24 (100%+)
it's because when it's hot, the air is not as dense. having a tuned engine means you have the right air-to-fuel ratio. when it's hot, there's less air going into your engine so you need slightly less fuel also to maintain the ratio. therefore, you lean it out a bit.
unsp0ken is offline   Reply With Quote
Old 07-27-2009, 06:17 AM   #10
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Running 270-280-290 degrees will shorten the life of your engine. Shoot for the 210-235 range. (under 200 will ALSO shorten the life of the engine!)
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 07-27-2009, 06:51 AM   #11
elkman's Avatar
Default This weekend
Outside air temps ran about 100F yesterday and I leaned the top end a little. I run a Houston-tuned JP and normally I run at 235F to 245. This Sunday I was running about 260F to 270F. It flamed out on me a couple of times, so did everyone else. I up-trimmed the idle at the engine and on the transmitter to help keep it from flaming out when it was idling. It was a difficult day.
"He's old enough to know what's right
But young enough not to choose it"
Neal Peart / Geddy Lee
****RUSH****
elkman is offline   Reply With Quote
Old 07-27-2009, 08:39 AM   #12
In hot weather things have to run hotter. Especially with the same plug. I use to race tune my engine around 230 at my home track. In 115 I was at 250. It was fine. It was new for me as at home I never run that hot. Every engine is different. You have to know what the engine likes and tune to smoke and sound. I can usually feel and hear what the engine wants and needs. It comes with experience. Best of Luck.
I need to try different plugs to see how that effects the temp and tune. Houston or someone else would have the answer to that question right away.
Chris Reilly is offline   Reply With Quote
Old 07-27-2009, 09:02 AM   #13
There's more to it than just temp. Humidity and altitude are big factors too. An engine tuned in 100 deg heat in Phoenix won't be right at 100 deg in Houston or Florida. Tune your engine so it runs properly, esp. make sure the bottom end is rich enough. Then check temps to be sure they're ok. We run 6 months out of the year at 95+ deg and high humidity and my engines are never above 220-230. Some of that depends on your engine too though. My Extech rarely temps over 200 LOL.
cjtamu is offline   Reply With Quote
Old 07-27-2009, 09:07 AM   #14
My example is from 2 tracks 12 hours apart. FTR upper NY to Dirtburners St. Louis. Humidity, saturation ..........
Old 07-27-2009, 02:51 PM   #15
Default engine tune
ya chris is correct other factors affect tune. and temp over 250 will lean and burn engine, i have not seen an engine run long after being that hot, have been through a few myself that way when i first started in r/c. all engine like certin temps go to web site of engine or blog's noting wheat other racers have had with temp's on that motor vspec like 250 all day long my jammin 28 like 225-240 anything over that leans crazy and flames out....
STEVE SACHUK is offline   Reply With Quote
Summer Rage Anyone? mafiaracers Northwest Racers 371 07-22-2008 05:13 PM
