Old 07-24-2009, 06:27 PM   #1
jhipps835's Avatar
Trader Rating: 13 (88%+)
Default Tire Gluing
Is it okay to take tires that are coming unglued off the rim then re glue them? Will everything still be good for use? And whats the best way to take glued tires off rims? I have some proline bow ties and crimefighter but the previous owner didnt do a good glue job. So i wanted to take them off and re glue them. Any help would be nice
Losi 8ight 2.0 - O.S V-Spec - Futaba - AKA - M8 - Spektrum - Byrons 20%
jhipps835 is offline   Reply With Quote
Old 07-24-2009, 07:05 PM   #2
jhipps835's Avatar
anybody???
What temp should i bake them at? And will i be able to use them after i back them???
Old 07-24-2009, 07:53 PM   #3
jhipps835's Avatar
bake not back* Typo
Old 07-24-2009, 07:57 PM   #4
az00lude's Avatar
Originally Posted by jhipps835 View Post
anybody???
350 degrees for about 10 mins. Let it cool then remove the tire. The foam might not be usable after that.
Xray xb808
az00lude is offline   Reply With Quote
Old 07-24-2009, 08:00 PM   #5
jhipps835's Avatar
Why what would be wrong with the foam?
Are there any methods that will not destroy the foams?
Old 07-24-2009, 08:02 PM   #6
az00lude's Avatar
Foams starts to break down into pieces as soon as you start using the tire on the track or get moisture from washing the tires.
Some people use acetone or boil it. I'd think that these will definately detroy the foams.
I do this to get old wheels off used tires so I discard tires and foams.
Xray xb808
Old 07-24-2009, 08:05 PM   #7
jhipps835's Avatar
Okay thanks.
Does it usually start to smell after a couple minutes?
Old 07-24-2009, 08:08 PM   #8
az00lude's Avatar
Okay thanks.
Yes, you'll start to smell the rubber. You'd not want to bake a cake until you air out you oven first. I use a small toaster oven for this and do it outside.
Xray xb808
Old 07-24-2009, 08:09 PM   #9
jhipps835's Avatar
Would a toaster work? I dont have a toaster oven
Old 07-24-2009, 08:10 PM   #10
johnny t's Avatar
once the rubber gets CA glue on it new glue does not take as well. you could go through the trouble of boiling off the tires and starting over, but the high temps could affect the rubber adversely. and just seems like alot of work for little gain.
how bad is your situation anyway? what I would do is to clean out the unglued areas with a q-tip soaked in motor spray. and glue with a quality tire glue like AKA's using some strong rubberbands for clamping, and burn them up in practice. if you run at LH they won't last long enough to worry about coming apart for too long.
If you need any help I will be practicing at LH saturday. just look for the blue and orange kyosho, using lots of throttle.
johnny t is offline   Reply With Quote
Old 07-24-2009, 08:12 PM   #11
jhipps835's Avatar
Thanks Johnny, I was thinking of coming out because by tomorrow ill have more tires. What tires do you run outdoors? Aka's maybe?
Old 07-24-2009, 08:15 PM   #12
EvilDylan's Avatar
I've boiled off a few sets of tires. Never really had any adverse effect, it was just very time consuming, and as the above poster said the tires never seem to bond the same once they've been glued the first time. with boiling though the foams seem unaffected.
EvilDylan is offline   Reply With Quote
Old 07-24-2009, 08:17 PM   #13
Trader Rating: 24 (100%+)
Jhipps, got some left over tires we just used at the nationals. Mounted up by the speed shop $40-$45 per set mounted.
I also have some unmounted stuff thats going for $26 a set.
Email or pm me and I'll send you a list.
Owner of the Speed Shop: A race prep shop for anything related to 1/10 and 1/8 off road racing. Check us out: https://www.facebook.com/pages/The-Speed-Shop/382214705269137?ref=bookmarks
ABURTON is offline   Reply With Quote
Old 07-24-2009, 08:20 PM   #14
johnny t's Avatar
for racing, cityblocks, either medium or hards. some guys are liking the proline calibers in xtr compound. for practice anything can work, I am not ashamed to say I have even used proline badlands.
I will be using expired cityblocks tomorrow, will try some proline knuckles just for kicks.
Old 07-24-2009, 08:22 PM   #15
jhipps835's Avatar
Cool tomorrow i will have 2 sets of city blocks and 1 set of i beams.
Have you ever tried that combo? Ibeams/Cityblocks
AKA tires ALG Nitro Off-Road 1793 11-04-2016 06:37 AM
‘FWR Racing Season’ FWR Northwest Racers 11302 08-23-2015 06:38 PM
Tires will not stay on wheels maximumhp Nitro On-Road 12 04-23-2009 04:52 PM
The art of tire gluing. CE28N Electric Off-Road 15 09-12-2008 05:53 AM
AKA Tires......Release Date? Newell33 Nitro Off-Road 69 09-11-2008 12:21 AM
COBRA RACING LOOKING FOR A,B,C MAIN DRIVERS AND LOCAL CLUB DRIVERS COBRARACING Nitro Off-Road 259 04-18-2008 06:25 AM
Tire Gluing acutts Electric On-Road 15 06-01-2005 04:04 PM
