Old 07-24-2009, 08:00 AM   #1
Default Drive hex pin melted/stuck in hole..
Hey all again, I was going to clean the wheel bearings out and re lube them and I was trying to get the pin out of the drive hexes [I have a duratrax raze st] and there is a little grub screw that holds the pin in there. So I took the grub screws out of 3 of the 4 axles [stripped one out thanks to duratrax's over-loctiting everything in, lol.] and when I try to get the pin out, they will NOT come out. Ive tried tapping them out with a hammer, mustleing them out with needle nose pliars, and then drilling them out =] lol. They will not come out.
I dont think its a big deal because everyone Ive seen run truggys has never broken a wheel bearing. They seem to be pretty big. Should I be worried about this or not?
I can still see the bearing a bit and I can spray them out sorta and get oil back there.
Im easy on my stuff so I wouldnt be bashing. Just some light friendly racing with friends on their tracks.
Thanks!
Kimixii is offline   Reply With Quote
Old 07-24-2009, 08:16 AM   #2
Use a heat gun -
When I put mine on - I use locktite and the lock tite actuall goes in and ataches it self to the pin, just use a heat gun get it hot and it should just fall out.
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 07-24-2009, 08:24 AM   #3
Really now? I never thought of that! Hope a hairdryer works because thats all i got Yeah duratrax put WAY too much loctite on everything. I mean I appreciate loctite but too much is a bad bad thing.
Also, do you have any ideas on how to get that stripped grub screw out? I used the right driver im sure of it, but it was baked in there pretty good and is stripped. I guess i could try heating that too then taking it easy?
Old 07-24-2009, 08:54 AM   #4
Unfortunetly that did not work. I heated it up, and it was as stuck as ever. I used purple power concentrated to try and remove all the gunk that holds it in, it didnt work. So now i guess thats it, I cant get it out, lol.
Old 07-24-2009, 11:41 AM   #5
Naa bro you needs a HEAT GUN, dog. A hair dryer is not hot enought to melt the locktite.
I purposely to that on my truck so I dont lose it. Heat gun - works best
Old 07-24-2009, 11:57 AM   #6
Dangit well im dirt broke so i guess imma keep the stuck pins in there. Arghh.
I didnt know a heat gun was any different from a hair dryer lol.
Old 07-24-2009, 12:13 PM   #7
fatdaddy's Avatar
heat gun is only $10 at harbor freight: http://www.harborfreight.com/cpi/cta...emnumber=96289
HPI Racing - Hot Bodies - D8 Army!
**Team Terribles** (Answer RC, Fastlane Graphix, Caster racing, M2C Racing, and Dialed Inc!)
fatdaddy is offline   Reply With Quote
Old 07-24-2009, 12:18 PM   #8
+2 harbor freight
Old 07-24-2009, 01:08 PM   #9
Akhor's Avatar
You can also use a bbq lighter..
Or a regular one.. But it would get way too hot.
--Blaine--
VBC D07, VBC D08
Mugen MBX 7, Mugen MBX 7 Eco,Mugen MBX 7r, Mugen MBX 7r Eco
www.rcgears.net, www.carcar.ca, www.karz.ca
Akhor is offline   Reply With Quote
Old 07-24-2009, 03:05 PM   #10
sickmojave's Avatar
Do you have a soldering iron. I think I would try that before I tried a lighter.
sickmojave is offline   Reply With Quote
