Old 07-22-2009, 05:59 PM   #31
Gearhead racer's Avatar
After Run Oil
"Seeing the world on 2 wheels"
Losi Ten-T SCTE~Tekin SC4X 4.5~ Tekin RX8
Gearhead racer is offline   Reply With Quote
Old 07-22-2009, 07:02 PM   #32
Jason's Avatar
Originally Posted by cheapskate.brok View Post
wouldn't it be great if AROs are available in aerosol cans
I've been running this oil for a while now. Buddy of mine has used it for years.
http://www.yamaha-motor.com.au/yshop...D=36&ProdID=21
| Team Orion | KO Propo | SPEEDLine Designs | RMS Graphix | HobbyTown USA, Rockford Il |
Jason is offline   Reply With Quote
Old 07-22-2009, 07:05 PM   #33
WD40 will actually promote rust, after run oil is by far the best way to go
devbloggs is offline   Reply With Quote
Old 07-22-2009, 07:27 PM   #34
um ok. Take two pieces of carbon steel and set them outside one with nothing and one with wd40 and see which one oxidizes first.
wd40 has never given me problems. I use aro but wd40 will not hurt your engine. If your in a pinch a squirt through the glo plug hole is no problem.
i have old engine parts that i have in airtight ziplocks with wd40 and there is no problem with them. And they have been there for months.
anything that will dry it out would be devastating though. Nitro blast, brake cleaner, de natured alcohol etc.
dreaux is offline   Reply With Quote
Old 07-22-2009, 07:33 PM   #35
http://www.wd40.com/faqs/
Old 07-22-2009, 08:49 PM   #36
CMB21's Avatar
No one has really answered his question of why not to use WD40.
This is what i came across while looking up info for after care in nitro engines.
" DO NOT UNDER ANY CIRCUMSTANCES USE WD40 AS AFTER RUN !!! It has a detergent that de greases and that eats the protective oil coating left in the engine. "
I only use after run oil, with all the money you put into your rig why risk it to save a couple bucks.
~Team Terribles~
Kyosho RB5 SP (Venom esc, Fantom Ion 2)
Team Associated RC8B (GO Engines, AMain C2 Fuel)
CMB21 is offline   Reply With Quote
Old 07-22-2009, 08:57 PM   #37
sokar's Avatar
The FAGs didn't say anything about using WD-40 as ARO.
sokar is offline   Reply With Quote
Old 07-22-2009, 09:03 PM   #38
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Yep WD-40 is actually a degreaser. There is a reason it's called After run oil. It's designed for it's purpose. I really think you can spend the couple extra bux to buy some ARO. WD-40 is great. Just not for engines.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 07-22-2009, 09:29 PM   #39
Integra's Avatar
I dont use any ARO...if my motor's are sitting for any extended period's of time they are dis assembled and stored dry in paper towel...even if im not racing for a good couple weeks i wont bother with ARO.
Old 07-23-2009, 02:22 AM   #40
Lonestar's Avatar
Castor oil is an excellent after-run for short storage times. Cheap as heck too, apply it with a syringe. Fully compatible with all motor components (remember a lot of fuels actually still use castor oil). Only issue is it gums up after a while... hence use it as week-to-week ARO and then use sthing different for longer term.
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 07-23-2009, 04:47 AM   #41
WD40 is used for un-siezing rusted parts and lining
insiginifcant thing that see little heavy use. Ask any mechanic and see how
much he uses WD40 instead of grease or oil.
Ask and skateboarder that know what he's doing and see what he or she uses on their bearings, If you use wd40, those bearings will be seized the day after you stop using them.
WD40 isn't for protection, it's mainly for cleaning and free-ing up things. All you'd be doing with WD40 is cleaning whatever oil from the fuel is left, out of the motor, leaving it exposed and viable to rust and corrosion.
So far. It seems like aro is by far the winner in this thread. You wanted peoples opinions, aro is their opinion.
Old 07-23-2009, 05:57 AM   #42
So last night I spoke with 2 engine modders - one in CO and one in CA
They both say, it is recommended NOT to use WD40 in an engine in replace of After Run Oil. The reason behind this is: 1) it is highly flammable and using to much in an engine blown out glow plugs and it can screw up the button head because it will not allown the glow plug thread to hold, becuase its used to ease the tention between screws nuts and bolts.
2)it is a degreaser/cleaner first and lube later. The oil they use in WD40 is a thin low content oil, for smooth surfaces the oil do not stick, it just slide off and settle at the bottom.
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 07-23-2009, 06:17 AM   #43
looper's Avatar
Trader Rating: 19 (100%+)
Send a message via Yahoo to looper
wd40's purpose has been water displacement, it does have minor lubricating properties as well, wd40 means water displacement 40th try. not saying pro or con on the aro aspect have used it for this with no problems and have heard to the contrary. but it is designed to displace water.
Looped Designs Paintwerks
http://ldpaint.webs.com/ Email: Looped.designs@gmail.com
looper is offline   Reply With Quote
Old 07-23-2009, 06:22 AM   #44
mrbusta's Avatar
Trader Rating: 20 (100%+)
Send a message via MSN to mrbusta Send a message via Skype™ to mrbusta
Default my opinoion not to offend
from what i have been led to beleive is that traxas have it in there manual to use wd40 as aro but i would suggest that its a great marketing ploy as use it and its not the best for ur motor so go buy another traxas wich is a good for buisness so they can have a big turn over not good for the new customers but as frank-l said wen u pay a lot on ur mill why stick shit in it why dont u use urine for fuel then if u eat shit ull pass farts galore and bad terds from ur rear so eat good and ull be healthy hense the motor is the life of ur toy so treat her with top quality liquids and she will treat u rite
SHAYNE/MONSTER ENERGY/BETA TYRES Australia
Thanks to www.wprcracing.com/P.N.D Paint works
81/MUGEN Mafia
RIP BUSTA BB ANGEL
mrbusta is offline   Reply With Quote
Old 07-23-2009, 06:53 AM   #45
sokar's Avatar
Well, that's polite.
Anyway I've heard good things about marvel mystery oil. MMO is $5 per quart when the hobbico stuff is around $5 per 2oz. Is the Marvel stuff the same or any better than ARO? Judging from the responses methinks I'm not gonna use any more WD40 in my engine, and I should probably warn my friend.
